Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Rancher 455 starts and runs for a minute then immediately stalls out. What's going on?
  • Husqvarna Master
  • 7,482 Answers
Hi David
Sounds like you have dirt/debris in your carburetor jets, fuel passages or a diaphragm that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a picture for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank. The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphragm may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting, start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a lacquer thinner type cleaner to clean and dissolve the lacquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the lacquer thinner because it can dissolve the plastic parts and render them unusable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages. The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right position for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring, you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 18, 2013
  • 1 more comment
  • David Seagraves
    David Seagraves Oct 19, 2013
    Thanks for your detailed guidance Bud. You have obviously dealt with similar circumstances yourself. I will not be able to tackle this project for about a week due to other obligations. I'll give you and update after I have had time to work on the saw. Thanks so much for your help Sir!
  • Curtis Sewell
    Curtis Sewell Oct 20, 2013
    Your welcome David...hope to hear how you turn out...just take your time, and all will be fine
  • David Seagraves
    David Seagraves Mar 12, 2014
    Curtis - the problem with my 455 Rancher seems to have resolved itself without further work on my part. I have used it a couple of times over the past couple of months and it is no longer stopping after a few minutes of operation. No idea what may have been causing this "temporary" problem! Thanks again for your instructions regarding a resolution to the earlier problem. I'll retain those for later use!
SOURCE: my 455 rancher won't maintain power. I have
If you have been running ethnol mix in your saw there is a good chance that your fuel vent line is plugged. Loosen your fuel cap and start saw on its side and see if it runs. If it does you will have to clean your fuel vent.
Posted on Aug 03, 2009
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
dontbother10
  • 2220 Answers
SOURCE: what is the longest bar i can go on my 455 rancher
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
Lou
Posted on May 14, 2010
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Not getting gas to the carb
Possibly dirt or other clog in the fuel line!
Oct 20, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher shuts off after it gets hot
The tank vent has been an issue, it can not only vacume the tank it can pressurise the tank and cause flooding, the breather is under the starter cover on the top right hand of the tank, i have replaced the original breather to the early 357xp breather, this is like a small white pellet of vion ( a breathable plastic )
May 13, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher runs for about 5 min. than stalls and wont start until cold than problem repeats
Sounds like a fuel problem. Something might be expanding as the saw warms up and is cutting off the fuel or introducing an air leak. Carby may require a new kit and check the fuel line
What is the recomended gas mixture for my 455 rancher husqvarna
All Husqvarna products for at least the 5 years are 50:1. As are every manufacturer with the exception of Poulan which is 40:1. If you are going to provide advice PLEASE take a few minutes to ensure it is correct! HTH
Lou
Feb 07, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Husqvarna 455 rancher I have been trying to adjust the idle and carburetor but it's still running a little rough. Any Suggestions?
husqs are sensitif for dirt in carb and fuelsystem clean everything real good. airfilter, carb, tankfilter. after building together make sure it can not take false air. start with both screws closed and open for 360 degrees. after that start adjusting. compression must be ok. saw must hang on cord and not go down. good luck lot of work.
Jan 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
151 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
