Question about CP Technologies Levelone WBR5400 Wireless Router
Netgear ce0560 default password - CP Technologies Levelone WBR5400 Wireless Router
99 s 10
Please reset your router and enter gain using the default username and password.
The default username and password for Netgear routers are admin and 1234 respectively.
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Nov 05, 2013 | NetGear Computers & Internet
Retrive password for netgear
Reset the Netgear back to the factory defaults to remove the password.
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 19, 2012 | NetGear N300 Wireless Router
What is my default ownership password netgear N600 only numbers
See the following articles for more information:
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
hope it helps
May 25, 2012 | NetGear N600 Wireless Dual Band Router
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
Lost password for netgear router wnb834b
  • Username = admin
Apr 20, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I am trying to configure a netgear wgt624 v3 router. I can't get passed the admin and password. Please help me configure this
  • Username = admin
Feb 12, 2010 | Computers & Internet
New laptop , now router unsecure; want to use admin and 1234 cannot find the screen to try that fix - do not know password created many yrs ago - do not have expertise to reset router;Netgear CE0560
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Nov 06, 2009 | Computers & Internet
Cannot get password authorisation for netgear router
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Apr 03, 2008 | NetGear DG834G Router
CP Technologies Levelone WBR5400 Wireless Router Logo
Top CP Technologies Computers & Internet Experts
CCervantes
rpar
Are you a CP Technologies Computer and Internet Expert? Answer questions, earn points and help others
