Question about Toaster Ovens
Hamilton beach 31197
I took off the elements and tested and they are fine. It doesn't heat though. What it could be ? Thermo ? The light turns on as if heating, the fan works but none of bake or broil heats. Got the elements out, made the test for continuity with a multimeter and it's OK, between 9 and 11.
  • Toaster Ovens Master
  • 2,113 Answers
Look for the thermal cutoff. Either it looks like a resister or it looks like circular thing. Test it for continuity
Posted on Oct 18, 2013
Testimonial: "I've found a rectangular metal piece in the thermo that is cracked, like it burnt, as a resistance. Wondering if I could improvise cutting some piece of metal to replace it. Any suggestions ?"
5 Suggested Answers
  • 11800 Answers
SOURCE: I am looking for a
Actually what they were meaning to say is that you can replace the resistance, but you will have to source it yourself since they don't sell spare parts because it's not profitable: this cheaply made chinese manufactured oven costs less than $100 new, the resistance costs about $15 and the labor to install it (almost all the customers aren't capable of fixing it themselves) another $100 which would make it cheaper to buy new so there aren't enough customer for spare parts to make it profitable to sell them.
If you still want to replace the resistance yourself the only source for another one is to extract it from a defective unit that you will have to find, either online or at shops that sell defective equipment.
Posted on Aug 05, 2011
SOURCE: Not Heating
I just opened one with the same problem. The bi-metal switch / thermostat was completely burned out and melted into a small lump of metal. Unless you can get a replacement for that it might be the cheapest to go to a store and buy one new for under $80.
Posted on Nov 30, 2007
SOURCE: my Hamilton Beach Toaster Oven Model 31197s will
I trashed the toaster oven. Apparently even if you know how to fix something you can't get the parts. If you need to take apart an appliance to fix it, you can rest assured you cannot get a replacement part. This is our throw away society.
Posted on Dec 19, 2009
  • 21 Answers
SOURCE: Hamilton Beach 31197 blower not working
There is no fuse. This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan motor is a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Posted on Jun 16, 2012
Apr 14, 2012 | Hamilton Beach 31197 120 Watts Toaster...
I need the manual to counter top oven model #31197
People keep asking for this even though there are others (now mostly dead links) so I have posted it (3 language edition) here:
http://66.39.50.3/Manual.pdf
Nov 15, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Is my Model 31197R repairable? The heating elements are not working. Fan is running.
Not worth repair unless you do it yourself. The replacement model oven for this is available at Wal-Mart for $69 and has the exact same design flaws as this model - inaccurate thermo, part on door mechanism that wears out, and short life motors. I still repaired mine as the oven is so large and the new ones have the same problems and 1.5" less height. Unless you are really into repairing electrical devices, I wouldn't attempt it as HB made this a tough repair. They will tell you the unit is not repairable and they built it with that in mind.
Nov 14, 2011 | Hamilton Beach 31197 120 Watts Toaster...
How to remove control knobs on Hamilton beach oven Mod 31197S
They are just held on as usual by spring tension (metal spring on knob and also on shaft flat) to the shafts of the internal parts. They are really on there though, so it is best (to avoid damage) to remove the two plastic pieces (with the feet) from the bottom, then the black exterior shell and carefully push with a small screw driver or other from the inside while gently pulling on the outside. Why do you want to remove the knobs?
Sep 28, 2011 | Hamilton Beach 31197 120 Watts Toaster...
What's your problem? I need an owners manual for a toaster oven
http://216.92.50.93/Manual.pdf
Sep 25, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Cannot control the temperature. Even when I put on the lowest heat setting the coils re bright red. What part do I need to fix it. The model is 31197S Series A2940BR
HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The thermo on all these units is inaccurate anyway as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Jun 15, 2011 | Hamilton Beach 31197 120 Watts Toaster...
My Hamilton Beach Toaster Oven Model 31197s will not heat. It appears that the temperature control element is broken. Where can I get a replacement part.
Dec 18, 2009 | Hamilton Beach 31197 120 Watts Toaster...
Not Heating
Aug 24, 2007 | Hamilton Beach 31197 120 Watts Toaster...
Toaster Ovens Logo
202 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
