Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell pro heat 2X pet will not spray water.
    Sergeant:
    Champion:
  • Bissell Expert
  • 357 Answers
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Posted on Oct 21, 2013
SOURCE: bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
Posted on May 17, 2009
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
  • 29 Answers
SOURCE: Bissell Proheat 2x Not Putting
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My Bissell model is different than yours, but many are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell Proheat Complete Pet 2x with Microban feature will not spray,water is not heating and a leak in the tank on the front of machine. Can someone help with this problem?
Hi there! I'm sorry you're having difficulty with your ProHeat 2X machine. I understand how frustrating this must be.
We have a terrific FAQ that will provide you with troubleshooting steps for the no spray.
Here's the link: http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Here's a quick link to help you with the heated water: http://www.bissell.com/FAQDetail.aspx?id=29300&cid=ccsocial
Sep 03, 2013 | Vacuums
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
Jan 15, 2013 | Vacuums
Bissell proheat 2x model 2400 will not spray water or cleaner
You will need to look in the front were the water comes out to see if the jets are clear. SOmetimes they get clogged up.
Nov 12, 2012 | Bissell 9400-3 ProHeat 2X Select Pet...
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
Bissell Pro Heat PET 2x
the element may need to be clean because when these units sit they lime up in the water way
Mar 02, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
317 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
