Question about Logitech Audio Players & Recorders
Chirping noise I have Logitech Z-340 speaker system that has worked well for several years. Recently, the subwoofer has begun making chirping noises. It lasts for about a minute and stops. It happens just a few times per day. I disconnected the cable connecting it to the computer and the noise did not stop. Anyone know what may be causing this problem?
  • 1,511 Answers
The cost is too great to repair.
Posted on May 09, 2014
CLUEPATEL
  • 138 Answers
SOURCE: subwoofer isn't working
If your wire connections are normal then the problem is due your woofer speaker. Its your subwoofer circuit error and must be repair thru replacing the damaged Component in the circuit
Posted on Dec 09, 2007
Drummernick
  • 440 Answers
SOURCE: Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Posted on Feb 11, 2008
  • 10 Answers
SOURCE: logitech speakers installation guide
Here is the link so you can download a manual: http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8263&p_created=1158961578&p_sid=h_qp_7hj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9ODQ0LDE3LDE2OTQmcF9jYXRzPSZwX3B2PTMuMTY5NCZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PW1hbnVhbA**&p_li=&p_topview=1
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
  • 69 Answers
SOURCE: Subwoofer humming/buzzing
It sounds like one of the internal solder welds to the cable or a/v connections inside the cable box is bad.
Posted on Dec 19, 2008
Can not get subwoofer z-340 to work with i3 laptop. Speakers work, but not subwoofer
Ensure it is connected according to the manual and plugged into a wall outlet for power. The small speakers might work just being plugged into the computer but the subwoofer requires a much higher voltage to run.
Sep 28, 2013 | Logitech Z-340 Computer Speakers
My Z5500 logitech subwoofer makes weird noises similiar to thunder, it doesn't matter is there input or not. it just makes "thunder" noices all the time and wont *******. what is wrong in it?
Most likely its broken... if its less than 3 years old, call logitech, they'll send you a whole new system for free without you having to return the old one. Just make sure you have your receipt.
Feb 27, 2011 | Logitech Z-5500 Computer Speakers
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Jun 03, 2009 | Logitech R-20 Computer Speakers
Our logitech z-340 speakers are not working and there's no power?
Plug the satellites into the subwoofer, plug the mini jack into your computer, plug it into a wall out, and turn it on.
May 30, 2009 | Logitech Z-340 Computer Speakers
15 inch velodyne subwoofer making a loud popping sound
If you have changed the signal source, then these may not be the problem at all, it may be that you have the sub output set to low on your processor.
This may be one of these problems.
It could be the "auto on" circuit.
If you change the switch on the back of the unit to always on does it still do this? if not then it is the auto on circuit that is the problem.
The driver mounted servo unit is starting to fail.
A cap in the amplifier input section may be going bad.
You nwill need to contact Velodyne for repair of the unit.
Feb 20, 2009 | Velodyne HGS-15 Subwoofer
Need wires for z-340
I just got one too. I guess I'll tear it apart and post the pinout. Also have a set of Altec Lansing satalites (ACS340) with the same connector (hmmmm, Z-340 -- ACS340... probably the same thing they just changed some pins)
I let you know!
Aug 24, 2008 | Logitech Z-340 Computer Speakers
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
175 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
