Soyo Topaz S - 24-inch Wide Screen LCD Monitor dont turn on
dodgecharger
  • 254 Answers
SOURCE: BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Posted on Sep 17, 2007
SOURCE: Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Posted on Jun 27, 2008
RyMS
  • 63 Answers
SOURCE: Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Posted on Jan 30, 2009
SOURCE: dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Posted on Mar 10, 2009
bob_computer
  • 3153 Answers
SOURCE: need 24 inch lcd monitor driver
There should be no requirements for a "driver" for a regular computer monitor be it lcd or otherwise. If you mean the colour management table as used for matching monitor to printer output then the westinghouse support section of the web is your best place to start
Posted on Aug 16, 2009
Won't power up
Bad power supply board capacitor, most likely.
99.99% probability.
(the other .01% is it is not plugged in)
http://www.ebay.com/itm/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-/330499791194
Sep 03, 2013 | Soyo DYLM24D6 LCD Monitor
I have a 20 inch monitor that the screen is off center.The picture is blank 2 inches on the right and part of the left is missing.
I am guess your have a CRT monitor. There should be a menu button or knob on the monitor. Press it and a menu should come up that will allow you to adjust the position and size of the screen display.
If you have an LCD monitor, the resolution of your desktop is smaller than the screens native resolution. There sould be a button marked "auto" press it and it should correct it. If not, find the desktop screen resolution section in your operating system (control panel) and make sure it is set correctly. If it is wide screen, set it to 16:9 and then set it to whatever has the word "Native resolution" written beside it.
May 14, 2011 | Soyo Computers & Internet
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting...
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Aug 06, 2010 | Soyo DYLM24D6 LCD Monitor
I have tried all option on the Acer screen so the
The resolution is done at the PC video output setting, not at the monitor, you should set the PC video resolution to be at monitor native resolution: 1920 X 1200 @60Hz This will give the correct aspect ratio of your display.
Mar 26, 2010 | Acer X243W 24" TFT wide format screen 24...
I do drawings in Autocad and Photoshop on my 24" soyo topaz s
to adjust the setting on your monitor follow this steps:
right click on the desktop-properties-click Settings Tab-here you find the Screen Resolution then you can adjust it how you want then click Apply and you're done.
Dec 15, 2009 | Soyo MT-NI-DYLM2058 Monitor
24" DOA Soyo Monitor
What size monitor were you using before? If you were using a smaller monitor and everything was fine maybe this new monitor is out of range for the graphics card. I've found that not all graphics cards, especially older ones, will not run a monitor as large as 24 inches. If you can, connect this new 24 inch monitor to a computer with a more powerful graphics card. If it works then you will know that the problem is with your computer. Also connect your old monitor and go into control panel and see what range and resolution your graphics card will support. You may need a more powerful card to run the new monitor.
Jan 11, 2009 | Soyo Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
