Question about Weber Grilling
Replaced battery and unit still does not ignite
    Scholar:
    New Friend:
  • 80 Answers
Not enough information. is battery installed correct? are all the module spades attached or grounded? is gas flowing so the bbq can ignite with a manual lighter? are the electrodes coated with grease so they will not spark? Are the electrodes 1/8-1/4 inch at the tip so they are able to arc?
Posted on Nov 07, 2013
How to replace ignition ignitor in 1993honda civvi
The igniter unit is called the Ignition Control Module (ICM) for 1993-'95 models but is the same part.
1. Disconnect negative battery cable.
2. Remove distributor cap screws and remove dist. cap and
seal. Slide off the leak cover.
3. Disconnect the three leads from the igniter unit.
4. Remove the igniter unit retaining screw and remove the igniter.
5. To install new unit, reverse the order of directions.
Feb 14, 2015 | Cars & Trucks
IGNITION FAILURE ON 280 ZX (82)
  1. Turn the ignition switch OFF. Disconnect the fusible link connector for the fuel injection wiring harness. Be sure the ignition is OFF before doing this. Disconnect the cold start valve wiring harness connector. Disconnect the high tension lead (coil-to-distributor) at the distributor and hold it 0.13-0.25 in. (3.3-6.3mm) away from the cylinder head with a pair of insulated pliers and a heavy glove. When the engine is cranked, a spark should be observed. If not, check the lead and replace as necessary. If there is still no spark, go on with the following system checks.
    1. Make a check of the power supply circuit. Turn the ignition OFF. Detach the connector from the top of the IC unit. Turn the ignition ON. Measure the voltage at each terminal of the connector in turn by touching the probe of positive lead of the voltmeter to one of the terminals and touching the probe of the negative lead of the voltmeter to a ground, such as the engine. In each case, battery voltage should be indicated. If not, check all of the wiring, the ignition switch and all connectors for breaks, corrosion, discontinuity etc., then repair as necessary
    2. Check the primary windings of the ignition coil. Turn the ignition OFF. Detach the harness connector from the negative coil terminal. Use an ohmmeter to measure the resistance between the positive and negative coil terminals. If resistance is 0.84-1.02 ohms, the coil is OK; replace it if the reading is far from this range.
  2. If the power supply, circuits, wiring and coil are in good shape, check the IC unit and pick-up coil as follows:
    1. Turn the ignition OFF.
    2. Remove the distributor cap and ignition rotor.
    3. Using an ohmmeter, measure the resistance between the two terminals of the pick-up coil, where they attach to the IC unit. Measure the resistance by reversing the polarity of the probes. If approximately 400 ohms are indicated, the pick-up coil is OK, but the IC unit is bad and must be replaced.
0900c152800716f1.jpgFig. 10: Connect the ohmmeter to the pick-up coil terminals-1979-83 models 0900c152800716f3.jpgFig. 11: Remove the screws (arrows) to detach the IC unit-1979-83 models
  1. If the resistance is other than 400 ohms, proceed with the following:
    1. Be certain the two pin connector to the IC unit is secure.
    2. Turn the ignition ON.
    3. Measure the voltage at the ignition coil's negative terminal.
    4. Turn the ignition OFF.
WARNINGRemove the tester probe from the coil negative terminal before switching the ignition OFF, to prevent burning out the tester.
    1. If 0 voltage is indicated, the IC unit is bad and must be replaced.
  1. If battery voltage is indicated, remove the IC unit from the distributor, by proceeding as follows:
    1. Disconnect the battery ground (negative) cable.
    3. Disconnect the harness connector from the top of the IC unit.
    4. Remove the two screws securing the IC unit to the distributor.
    5. Disconnect the two pick-up coil wires from the IC unit.
WARNINGPull the connectors free with a pair of needlenose pliers. DO NOT pull on the wires to detach the connectors.
    1. Remove the IC unit.
  1. Measure the resistance between the terminals of the pick-up coil. It should be approximately 400 ohms. If so, the pick-up coil is OK and the IC unit is bad. If the resistance is other than 400 ohms, the pick-up coil is bad and must be replaced.
Oct 13, 2008 | 1983 Nissan 280ZX
Tip
How To Fix Grill Igniter No Longer Working
<ol> <li>If you have a battery type igniter, first try replacing the batteries.</li> <li>What you need to find out is if you are getting a spark in the igniter unit. The igniter is going to be near one (or several) of the burner(s).</li> <li>Some grills have independent ignition and some have a single igniter.</li> <li>If you have independent ignition and none of the burners will light then you have a faulty button or the wiring is bad. You should get these parts replaced.</li> <li>If you have independent ignition and one of the burners will not light or you have a single igniter and none of them will light you probably have something clogging that igniter.</li> <li>Pull off the cooking grates and barrier to get down to the burner.</li> <li>Locate the affected igniter and push the button. You should see a spark.</li> <li>If the igniter is clogged, carefully clean it out and test it again.</li> <li>If there is nothing clogging the igniter then you need to inspect the wiring. Faulty wiring or switches will need to be replaced.</li></ol>
on Feb 18, 2011 | Grilling
Zx7r faultsMy zx7r, ive got no Ignition or Neutral light, I have replaced the ignitor unit,the clutch switch, the battery,the side stand switch,the junction box, the fuel pump and still no ignition? I
CHASE YOUR POWER FROM THE BATTERY TO THE SOLENOID AND THE STARTER, IS IT IN NEUTRAL , MOVE THE BIKE BACK AND FORTH, MOVE EASILY CHECK THE NUETRAL SWITCH ON THE ENGINE IS IT GROUNDED.
Jun 03, 2013 | Motorcycles
How to remove ignition switch from 95 kawasaki 750 zxr
you need to remove the top yoke...turn it over and drill out the shearheaded security bolts that mount the ignition unit...re-tap the threads and use replacement cap headed bolts
Mar 18, 2013 | Motorcycles
Blew ignition fuse car will not start
need to check where the short was from, the coil or the ignition unit.
If so rectify or replace the unit to proceed.
Please check this link for possible errors in poor starting.
http://www.fixya.com/cars/r5843031-tips_check_car_not_start
Sep 30, 2010 | Pontiac Sunfire Cars & Trucks
My electronic ignition on gas Wolf cooktop(30 inch) isn't working on any of the burners. Why?
Is the ignition battery or mains electric? If it's battery,check the battery isn't flat. If it isn't it will be the ignition unit.
If it's mains electric it's more than likely going to be the electronic ignition unit.It is quite a fiddly job to change/test this. I would highly recommend getting a qualified 'Gas Safe' engineer to check it out.
I hope this helps.
Jul 08, 2009 | Cooktops
Outdoor grill igniter not firing
The actual ignition unit itself (not the battery) is dead.
Feb 27, 2009 | Grilling
Truck will not start
The vehicle will have a solid state ignition system. Distributor,control unit, pulse generator and ignition coil. The distributor is basically the same as in a conventional (Kettering System) car ignition. The difference is that the capacitor and breaker points are not used. Instead these are replaced by a pulse generator, consisting of a reluctor which rotates with the distributor shaft, a stator and a pick-up-coil mounted on the distributor base plate. There is no contact between the moving parts. The #1 suspect would be the control unit, which is a discrete non-adjustable electronic switching device which determines the period wduring which current will flow in the primary circuit. (i.e. 'The Dwell Angle") The control unit ALSO controls and interrupts the primary circuit when triggered by pulses from the oulse generator. (This induces current to flow in the secondary circuit) Take note that the ignition coil is a special design and should NOT be replaced with a coil from a conventional car ignition system. You should check continuity between all the wiring connections linking the coil, distributor and the control unit. Make sure that earthing points are effective and clean. Check that there is a proper connection between the distributor + and the control unit and esspecially the connections on the coil. Sometimes the vehicle ignition switck can be faulty but it is rare that it is so. The risk is if you do not know what you are doing, you could damage the solid state circuitry in the control unit. Check also the distributor cap, the ignition coil HT lead, see if you can get a spark whilst someone cranks the engine over. The testing procedure is too long to describe here. But email imsuze56@gmail.com for detailed information if you need it.
Jun 12, 2008 | 2001 Chevrolet S-10
Grilling Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
