Question about managemylife.com
My kenmore side by side refrig fan is working, the condensor is working, the mother board digital display is working, but fridge is not cooling, it is very warm, model number 10552562100 serial SL 3146094,could it be that it is low on freon, or does it use freon at all?
    Problem Solver:
  • 18 Answers
Refrigerators don't generally leak refigerant like cars have a habit of doing, so we can likely rule that out. Far more likely is your thermostat is bad. If you're handy, you can probably get the part at repairclinic.com.
Posted on Oct 18, 2013
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Fridge not cooling enough... Repairman said that the board has gone bad but everything works fine other than the fan...Was he just trying to sell me a $400 board or what?
Sounds like either your evaporator fan is bad, or your condensor fan is bad underneath your fridge or your condensor lines are dirty. I would check those things out first.The evaporator fan is located in the freezer behind the back panel. You should be able to here and feel the fan. Good luck!
Aug 20, 2010 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
My frost free fridge freezer comes on for five minutes every half hour and is not cooling very well, what's the reason for this?
1 Check the thermostat settings i.e. temperature control. Hope it is not on the lower number. 2 If the thermostat setting is OK then there is every possibility that the cooling gas has leaked out. Call the technician and get it recharged. 3 Also check the compressor that it is working properly.
Jul 31, 2010 | Refrigerators
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Have side by side ge, not cooling correctly, only indication i got was things freezing in fridge a couple of days ago, now not cool enough
Hello
Have a look under and behind the refrig,see if there is dust and dirt on the condensor and condensor fan.
If so, lightly take a vacum and sweep it off.Also claen any dust off the front grill located at the bottom.
If this doesnt help you may have a bad defrost timer or your low on freon,which would require a service call.
Thanks
Apr 14, 2010 | GE GSL25JFPBS Side by Side Refrigerator
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Feb 21, 2009 | GE GSH25JFR Side by Side Refrigerator
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
managemylife.com Logo
63 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
