Question about Kenmore Dryers
Managemylife com sears
I have a Kenmore gas dryer 11072952100 heats up for 3 min then shuts down then heats up again for 1 min then shuts down again replaced thermistor,and check with ohm meter .I still have same problem help me please jack
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Ohms out the two gas solenoids. You might find one open. Replace both.
Make sure the vent/air flow is not restricted.
Posted on Oct 19, 2013
catriver
  • 878 Answers
SOURCE: Kenmore Dryer
Marco, looks like you covered a venting problem and with the fact that you changed all the thermostats, leads me to believe that your primary and boosting coils are not functioning as they should. This are located on the gas valve. A sure way to tell is by observation. The ignitor will glow, you will hear a click and the flame should start. If it glows, clicks and does not start you can be assured it's probably your coils. Pretty inexpensive to repair. The part numbers are 5303307292 for the secondary coil and 5303307292 for your booster. Make sure to change both.
Posted on Apr 30, 2006
  • 1214 Answers
SOURCE: Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Posted on Jan 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dryer gets warm at first but then cools down
Check the hi limit thermostat and the cycle thermostat. They may be opening too soon.
Remove the connecting vent on the rear of the dryer exhaust and see if it cycles normally.
The flame sensor may be malfunctioning.
If the gas valve coils are good, these are the only other possibilities.
Posted on Mar 28, 2009
  • 84 Answers
SOURCE: 1 yr old Amana dryer mod#NGD7200TW won't dry
You either have a clogged vent, or the gas coils need changed..
Posted on Jan 12, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 11, 2010
That's not a website question. Please ask this question in a different category.
Jul 03, 2013 | Computers & Internet
Sears Kenmore gas dryer not heating up
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
May 03, 2010 | Dryers
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
My dryer will heat only for about 15 mins
you didn't say if it's gas or electric,sounds like bad gas coils,when they're on there way out they work until they heat up and then shut down,after they cool they'll work again
Jan 26, 2010 | Kenmore 63942 Dryer
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Gas dryer
Hi. thanks for the question. the problem is with the coils, at the gas valve. 2 round solenoids .1 with 2 wires to it. 1 with 3 wires to it. replace them . thanks te appliance doc
Jun 08, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
