Question about Car Audio & Video
Maxtek radio in mk1 ford focus only works when first conected
So the radio (maxtek 55401) works fine when first connected, so in it goes. A quick test of ignition off and on again and it still works. However if the car is left off for any length of time, the radio doesn't come back on. When I start the car, the backlight comes on, but it won't actually turn on. Then when I turn the car off, it beeps for 5 seconds and then fades for 2 seconds then is cut off. I assumed it was the ground connector(black&yellow AND black&green), for which the radio instructions and other the internet sources seemed to disagree, but i've tried it both ways and it gives the same result. could it be a security feature? or could it be something to do with the power antenna lead (unused) all help MUCH appreciated thanks mike
  • 33 Answers
SOURCE: Panasonic CQ-C1335U CD/RADIO FOR AN AUTO
what kind of car do you have a Chevy by any chance?? Any way that red wire needs to see 12 volts in order for the radio to turn on. But this is the wire that should get power when the key is turned on NOT directly to the battery. By the way, If you wires to the battery make sure that you have a fuse no more than 6 to 10 inches away from the battery. You should no matter what make you have be able to find a constant 12 volt for the yellow wire and a ground for the black in the dash. Hit me back with year make and model and I'll let you know how to find some ignition.
Posted on Nov 28, 2007
DrElectrics
  • 199 Answers
SOURCE: car radio /clarion db315 pro audio
try this
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 18, 2008
c renner
  • 43 Answers
SOURCE: installing a pioneer stereo in a 1995 honda civic
I'm assuming that you're connecting to a wire harness that you've purchased and not directly to the wires which were plugged into the original Honda radio.
The black ground wire from the Pioneer can be connected to the ground wire on the car. You are correct on the blue/white remote turn-on wire as well - it can be connected to the blue power antenna with no harm. If you were installing any amps the blue/white wire would also go to their remote turn-on input.
Posted on Feb 21, 2008
  • 226 Answers
SOURCE: Car just stopped running. Lost power suddenly.
Find an inductive pickup indicator for spark. Place on distributor cap to see if spark is at coil internal tower. If no spark at internal tower, look at ignition module or pickup coil. Ignition modules are prone to failure on 626's. But if you have spark at tower but not at the wire end, then your rotor is gone.
Posted on Aug 18, 2009
duane_wong
  • 6826 Answers
SOURCE: I am now the proud owner of a used Pioneer
http://www.carwale.com/accessories/items/pioneer_deh_1650_head_unit-372.html
The above describes the unit in detail with specifications.
It does not mention a code necessary.
http://audio.manualsonline.com/manuals/mfg/pioneer/deh1650.html
Here you may download the manual for this unit.
I hope this helps by providing the online resource links to you that should direct you further.
Have a nice day. And good luck installing your Pioneer CD deck in your car or truck.
Posted on Jul 24, 2010
How do I connect a warning/ignition light to my alternator?
Hi Glen
All depends what you mean by warning lamp.
Early Alternators used to have a terminal connected to the "Star" winding inside. A 12v lamp connected between here and ground will light up when a charge is available.
But.... the simplest method is to buy LED charge lamp which checked for voltages above 12v (12.5 to 14v} and lights up showing a charge. I can buy a simple device like this from my local Jaycar Electronics store. You should be able to get a similar device depending on where you are
Good Luck
You searched for alternator test
Oct 07, 2015 | 2004 Ford Focus
What are the d1&2 fuses on a 2000 Ford Focus?
On this website you find fuse box diagram description for Ford Focus mk1
Ford Focus MK1 fuse box diagram Auto Genius
Jul 27, 2015 | 2000 Ford Focus
Where is fuse 64 located?
It is in the fuse panel in the engine compartment. It is for the blower motor. Here's video showing the location. Replace Fuse 2008 2011 Ford Focus 2009 Ford Focus SE 2 0L 4 Cyl Sedan 4...
Jun 11, 2015 | 2000 Ford Focus
2006 ford focus fuese box location end diagram
There are 2 locations in your vehicle that have fuses in them. The description of the locations of those are below. Also below are diagrams of the fuse layouts for each as well as a description of what each fuse is for. This should all be in your owners manual if you have one. If you don't and would like a copy, you can email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy. No worries no cost for it. I hope this helps and good luck.
Jun 28, 2011 | 2000 Ford Focus
2000 ford focus sedan 2.0 dohc ztec engine rear
check all battery leads and earth straps
"" car body and engen bay straps""
also check battery terminals are tight check its full of battery water too if its been low for a time bump it!
and have a ""drop meeter test"" done on the battery if its a bad battery it should show that up first time it could have cracked plates inside the battery its self, test by turning on head lights then hit starter, if every thing go's dead!!!! put ""good jump start"" battery on to car and try it again,,, all should work just fine then,,,,it could just be a flat battery?????
Oct 27, 2009 | 2000 Ford Focus
I have 2005 Ford Focus and radio will cut out on me. I can't use the cd player/radio but the panel still lights up. I can see me changing the channels, volume etc but no sound. It does this every so often....
check all conections to the head unit and make sure there in the ryt place n lso check the wires at the other end at the speeker jus seemsly a loose conection sumwere to me
Oct 06, 2009 | 2005 Ford Focus
Cant tune radio
IS YOUR AERIAL CONNECTOR CONNECTED
Apr 05, 2009 | 2004 Ford Focus
Central locking broke on ford focus c max 2004
Fuse No 64 on back of fuse box inside cabin behind glove compartment undo two bolt and turn fuse board around pull the wires gently apart to see fuse 20 amp
Nov 07, 2008 | 2004 Ford Focus
Ford focus radio display is out
The display of the radio has micro contactes around the edges of the display. The cleaning agent used to clean the dash area could have been damaged. Best reccomandation is to have the unit replaced or taken to a repair shop and have the face plate repaired.
May 29, 2008 | 2003 Ford Focus
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
