Question about GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator
Bottom freezer ice maker overflows with ice cubes
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Make sure your contol arm moves up and down freely, arm is down to make ice whe ful arm must be up to shut down ice maker
Posted on Oct 19, 2013
Krazytech
  • 725 Answers
SOURCE: ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Posted on Aug 26, 2007
SOURCE: GE GSS25LGM Ice maker
Our Ice maker quit working. Won't make ice, but will dispense water. I unplugged the refrigerator and plugged it back in. I noticed that the green light on the ice maker is now blinking. It was steady on before I unplugged the fridge. Any ideas?
Posted on Feb 12, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Why is my ice maker causing blocks of ice at the bottom of ice bucket ,also on freezer baskets ?
Sounds like there is a leak in the water fill line to the ice maker or the timer in the ice maker is defective causing the fill cycle to overflow the cube tray and then freeze into blocks in the freezer.
Oct 08, 2014 | Kenmore Refrigerators
Can't open bottom freezer draw. It seems to be locked. How do I get it open?
IF YOU HAVE AN ICE MAKER IT MAY HAVE OVERFLOWED AND FROZE THE DOOR SHUT. AND IF YOU ARE SURE IT IS NOT FROZED WITH WATER THEN YOU ARE GOING TO HAVE TO FORCE IT. OTHER WISE BE SAFE AND UNPLUG. LET IT THAW AND TRY AGAIN AFTER 24 HOURS.
Apr 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795-75202400 icemaker problem.
Good day,
Either the water valve opens to fill the ice maker cavity, and doesn't shut off soon enough, causing the ice maker to overflow.
Normal file time is approx. 7 seconds.
This is the most common problem.
As well, it is possible the micro switch in the ice-maker that tells the valve to open and close has malfunctioned.
This is all based on the fact that the freezer maintains a normal temperature.
To test the freezer for consistency, place a plastic glass in the freezer half full of water.
Check it in 8 hours. It should be frozen solid. Then place the glass in a plastic bowl, and lay the glass on it's side. Recheck in 24 hours. The ice should remain in the glass.
If not, there is a problem with the refrigeration system.
Nov 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice cube tray overflowing-not shuting off automatically
Yes that is a plastic extension for the icemaker shut off. When replaced the new one should be secured with two small zip ties. You can use the ice on/off button to shut the icemaker off manually in the mean time. When ice is displayed in the panel it is on and when it is off so is the icemaker.
Jul 20, 2009 | Sub-Zero 650 / O Bottom Freezer...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
