Question about Honeywell VR8200A2124 Standing Pilot Gas Valve 1/2 NPT w/ Thermocouple
Honeywell troubleshooting not working - pilot will not stay lit even with new thermocouple
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot won't stay lit
Possible thermocouple is defective. The thermocouple is heated by the pilot itself, the theory behind this safety design is so the main burner cannot come on, if the thermocouple won't stay hot, it reduces the chance for a huge gas buildup in the burner compartment and possible explosion.
I have also seen cases a pilot would not stay lit if the flue for the heater is blocked by a spider web, bird nest or other obstruction.
Check and make sure the flue/vent is absolutely clean and clear, if it is, then the thermocouple may be defective. If you have an electric pigtail on the thermocouple, the problem may be the electronics or circuit board.
Here is a link to a photo of a thermocouple
https://www.centraltrailer.com/cart/images/2631-3481.jpg
Dec 22, 2009 | Whirlpool Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Honeywell VR8200A2124 Standing Pilot Gas Valve 1/2 NPT w/ Thermocouple Logo
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
