My Philips bdp3100 wont power up. It has an intermittent faint red light
Would like unlock code for Philips HTS5593 Blu ray
To make your Philips BDP3100 region free (this works on a BDP3100/05 purchesed in the UK in June2010)
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
Please note, the above hack has only been confirmed as providing region-free DVD, not Blu-Ray.
Mar 14, 2013 | Philips HTS5593/12 3D Home cinema system...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 28DW9625 - has an intermittent fault where it will turn itself off - like it is going into standby - but the red light flashes and I have to switch off, wait a few minutes, then switch on again....
philips has a problem with bad electrolytic caps in power supply-you can eithor replace the swollen caps in the power supply-pretty easy if you use a solder iron.if not go to shopjimmys.com enter model number-scroll down til you find power supply--after it arrives plug in new one
Sep 11, 2009 | Televison & Video
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips tv error code
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Aug 17, 2008 | Philips 50PF9830A 50 in. Plasma HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
