Reset optoma DAESUUG - Office Equipment & Supplies
OPTOMA PROJECTOR hd25e LOCKED CENTRAL PANEL AND IR DISABLED HOW TO FIX
Your problem same like me,just hold on the ENTER button 7 second and than press the SOURCE button,the projector will auto reset.
Dec 17, 2014 | Optoma Office Equipment & Supplies
PASSWORD CODE FOR OPTOMA EX550
Pass-code default value is "Right-Left-Down-Up" (first time).
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 06, 2014 | Optoma Technology Optoma EX550 DLP...
Reset lamp optoma tx615
HI,
Do the following for lamp rest after powering ON the projector.
Press "MENU"--> Select "OPTIONS" --> Select "LAMP SETTINGS" --> Select "LAMP RESET"--> Select "YES"
Ajin
Apr 27, 2012 | Optoma TX615 Projector
I have a Optoma projector HD70 How do you reset the lamp operating time?
hi,
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
ok
Jul 08, 2011 | Optoma HD70 DLP Projector
Optoma EP751, Just got a white boarder from top to bottom. Left.
try to reset.... or clean the board between av board and main board.
Oct 29, 2009 | Optoma EP751 EZPRO DIGITAL PROJECTOR...
Optoma h 27 will not power on at all. New lamp still not working.
Never heard of a heat reset. If the unit is completely dead. investigate lamp, and or lamp door interlock switch.
May 18, 2009 | Canon LV-S3 Multimedia Projector
Reset bulb hour counter.
hi,this should be in your menu and should b under lamp reset
Apr 25, 2009 | Optoma HD65 DLP Projector
Optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
Mar 15, 2009 | Optoma DX605 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
131 people viewed this question
k24674
jasbo
jasbo
