Sony powerplay up faint intermittent red light
I can see faint blue lines occassionally, is this a convergance chip problem?
One of two problems you have.
One is if you go to a unused video input, you should only see the video input number in green, ie video 1 etc.
If you see some blue in the background or faint curved lines you have a screen problem--it may be adjustable and I can tell you how.
Second, these sets rarely have intermittent convergence problems: Picture will look 3d in some way red, green or blue outlines etc.
Let me know which you have and I will help.
The model is more prone to the first problem than the second. Reply to this post with a comment if you need my help.
SD TECH
Jun 20, 2010 | Sony KP-57HW40 57" Rear Projection...
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
42" red light on, dim light appears on screen. bulb just replaced
Sony has had alot of problems with the light engines
and your set is DLP. Call Encompass Parts Distrubtion for Part number and Price then go to E-Bay look under Electronics tpye in part number .I have found same Parts Alot cheaper on Ebay,some by as much as $300.00
you can Google website or call 1-800-638-3328
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I need the wiring connections for a Craig amp #V501
THE SOLID RED IS USEUALLY UR POWER NOT SURE ABOUT RED WHITE WIRE ON AN AMP THATS A FIRST FOR ME AND IVE DONE LOTS AND LOTS OF CAR AUDIO INSTALLS
Feb 08, 2010 | Car Audio & Video
Flashes yellow then turns red
Oh dear look up yellow light of death their is a way to fix bit nasty though and you have to pull it all the way down to the bottom be very very carefull not for the faint harted or backyarder youtube has a file ion this but seriously consider this as a second option
sony will exchange it for about 330 in aust probably cheaper everywhere else Sorry
Aug 24, 2009 | Sony Playstation 3 (PS3) Console
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Faint red blotches on the screen of my 52inch sony wega
If this is the model with a light engine, then there lies your problem. Your filters in the engine are burning up. The light engine will need to be replaced. If this is an older model with the 3 tubes you might be able to adjust your red green and blue tubes to get the picture back in good standings. Please keep in mind when asking questions to include both the make and model number. This will help us help you more efficiently.
Oct 05, 2017 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
