Question about Samsung Bp47-00043a Lamp-ballast Vidi 65 Oem Original Part
Do I need to replace the lamp ballast on my Samsung Model HL56A650C1F? I have burned up 3 replacements lamps in approx. 9 months.
SOURCE: Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
Posted on May 08, 2008
  • 1694 Answers
SOURCE: Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Posted on Jan 24, 2009
  • 49 Answers
If you have already replaced the lamp and ballast, to no avail, then it is time to take it in to a certified repair center.  Most will charge a nominal diagnostic fee.  My 61" did the same thing and it turned out to be the Light Engine (of which the DMD Board is a part).
If the problem were the color wheel, the lamp would come on for a bit until the color wheel sync couldn't be achieved and then it would turn off.  The all-3-flashing-lights problem is the lamp.  Here is a page from the service manual on the 3 blinking lights problem.
The Light Engine controls the ballast via a separate signal than the 320 Volts.  The voltage reading means that the Power Board is working properly.
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
saidneurot
  • 128 Answers
SOURCE: Need to reset the Lamp counter.in my Samsung HLR5667W
here you go here is this web site where you can see how to reset your lamp
Posted on Jan 15, 2010
TV turns on but lamp never comes on. Seems to try 3 times then all 3 led's on front start flashing. I tried to replace the lamp but problem remains.
If the Lamp has been replaced then problem will be either Lamp Fan or Ballast board .
Ballast board connects to Lamp and it is what powers Lamp on.
Check out Encompass Parts Distribution type in your Model number for a List of Parts/Prices and Part Numbers.
Samsung Parts 1-800-627-4368
Jun 23, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W will not start up. Goes through 3 cycles and then lights in center circle blink. A new lamp was installed 2 months ago and it worked fine. The first time it didn't start-up, I unpluged...
Ballast Board ,it connects to the Lamp which is what Powers Lamp on.
First check all fans Lamp fan,ballast fan,DMd Fan, if they are OK then replace the ballast Board.
Encompass Parts Distribution 1-800-638-3328 Go to their website they have Free Service Manual
that you can print out for this Model.
Jan 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Have to frequently replace lamps on Samsung 50% rear projection
U hear many clicking atemp,before the tv even turn on or trying to turn on.Ur ballast it dying or dead.Replaced the Ballast to solved this.
May 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
I have a Samsung DLP Model number HL-T5075S that is giving me problems. Works for about 2 or 3 minutes then dies. I get the 3 LEDs that mean "Lamp" however the lamp has been replaced with Model #...
Hi,Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.The ballast is the most common failure on Samsung sets it has a sensor that detects if it's not lighting up the lamp or if the lamp is not responding.Pay attention to any sounds your tv makes. Here's the link to replace the ballast :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Have a blessed one!
Mar 24, 2010 | Samsung Televison & Video
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
Replaced the lamp on 50v710 keeps on burning out
You have a bad Ballast. This can be repaired sometimes by replacing the capacitors on the Ballast circuit board.
Jul 29, 2009 | Televison & Video
Samsung Bp47-00043a Lamp-ballast Vidi 65 Oem Original Part Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
