Question about KDS Computers & Internet
Picture on Monitor has shadows and is blurry and colors are mostly blue, green, purple. Print (text) is okay. Any solutions? Thanks
    Problem Solver:
  • 15 Answers
Did the problem occur out of nowhere? Is it a new monitor and was like that from the start? Is it an old monitor? Laptop? LCD? There isn't enough information.
However, try setting all video settings to default or "recommended". If that doesn't work, be sure your video card and display drivers are updated.
Posted on Oct 18, 2013
SOURCE: My monitor crt a90f+ viewsonic blurry
Ensure that the monitor's UltraBrite mode is off, via the "UltraBrite Mode" button on the front panel. UltraBrite is great for games and movies, but it tends to fuzz plain text ever so slightly.
Posted on Oct 16, 2006
banar
  • 26 Answers
SOURCE: demagnetize computer monitor
It looks more with screen resolution problem, if it is new then the best option is get it replaced.
Posted on Dec 12, 2007
  • 5 Answers
SOURCE: Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Posted on Feb 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Monitor Picture is Blurry because of shadows
If you've already checked all your cable connections, to make sure they're tight, check your windows settings: Go to Start>rt click My computer, choose properties, settings on performance, and choose adjust for best performance. (This will uncheck the shadow options for menus and icons, etc.) Take a look at your desktop. Is that better? If so, you might want to do some maintenance to improve your system performance by clicking here.
If no improvement, download or open the .pdf user guide for your monitor by clicking here. See pages 22, 17, and 12. They will show you how to use the auto button on the monitor to reset to optimal settings, to adjust the refresh rate (control panel>display>settings>advanced) to its optimum. (Normally, higher refresh rates indicate clearer pictures, but some LCD monitors seem to run better at a default 60hz rate. Check your Gateway documentation for your graphics adapter to see what it supports, (your monitor supports 60, 70, & 75), or experiment.)
If adjusting settings doesn't improve anything, you could search for updated drivers for your graphics adapter. Go to windows update and see if you're offered hardware updates, or search Gateway support for newer drivers.
Not many options left. See here.You could take it in to a local tech and have them take a quick look.( or try it on another computer).
If it's on its way to a sad end, I'm sorry. We have the same monitor at home and it's been great. Aside from a scratch someone put in it years back, it provides very clear resolution.
Posted on Apr 18, 2009
micromend
  • 748 Answers
SOURCE: why is the monitor turn weird color either green or blue not normal color I can see?
Take the monitor back, it's failing.
Posted on Apr 27, 2009
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Colors not correct
it sounds like a print cartridge problem to me.
sometimes they have other problems. try to replace the cartridge. if this does not work then try replacing the print head
Dec 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Color Resolution
Sounds like a piture tube or internal video driver in your monitor. You probably lost the green channel. If the monitor is dated I would replace it.
Aug 31, 2008 | X2Gen MG19MY 19" LCD Monitor
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Has a shadow on picture. Red, Green is not alligned
You need to set your convergence. Check your owner's manual on how to do it. I'm not sure the exact procedure on that model, but usually you can find it in the setup menu of the tv. What you're trying to do is line the red and the blue up perfectly with the green so that they all blend together to give you one picture.
Oct 20, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Computers & Internet Logo
48 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
