Question about Whirlpool duet Washing Machines
Whirlpool Duet washing machine model# WFW9451XW00 started powering on and off by itself. You could still manually turn it off or on but it would power on and off by itself. So I locked the controls by holding the lock controls button for 3 seconds. Next day I placed a load of clothes in the machine and it started just fine but 10 minutes are so into the cycle it started beeping and before I thought to look for any code I pushed the cancel button and it started draining. Now it will not power on, no buttons work except for the controls lock button. I replaced the Microcomputer Machine Control (MMC) and pushed the power button and it turned on but I had to leave so I pushed the power button and turned it off. When I returned, approximately 30 minutes later, it would not power on again. The only button working is the control locks button. Please advise/ help. Thanks!
  • Whirlpool
    Whirlpool Oct 18, 2013
    Hello Whirlpool Duet, we are sorry to hear about the frustrations you have experienced with your washer. Please email us directly at Whirlpool.Digital@Whirlpool.com with your phone number, address, and the complete model and serial number for your washer. Please also include this reference number: 62330. Best, Ashley
    Master:
  • 818 Answers
Check all the wiring connections-ie pull them apart and put back together-computer stuff doesn't like/read partial voltages-cheers Denny
Posted on Oct 19, 2013
  • 111 Answers
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jun 18, 2009
quare3
  • 48 Answers
SOURCE: Whirlpool Duet GHW9400PL front loading washer-control locked
I would suggest it would be better for you to bring it to repair person expert o washers. Because of the voltage fluctuation most likely they need to change some parts.
Posted on Feb 06, 2008
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
donnastr
  • 10 Answers
SOURCE: Whirlpool washing machine power button won't turn the machine on
defective timmer
Posted on Oct 08, 2008
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
No water to a Whirlpool Front Load Washing Machine (model # wfw9451xw00) ?
no power getting to the inlet solenoids from a problem program board or faulty water level switch
call a technician for a proper diagnosis
Jan 09, 2017 | Whirlpool Washing Machines
Started Duet without water turned on. Now have error code.
go here and find your manual this will help
www.whirlpool.com.au
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
LED works, but when press start power turns off Whirlpool Duet Sp
No reset, control is probably bad. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Washing Machines
Washing machine won't start
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
231 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
