Question about Home
Dusting duracraft high velocity floor fan blades
  • 2,113 Answers
I usually dismantle fans and wash the blades in the sink and then put it back together.
Posted on Oct 18, 2013
Hi, I have a Duracraft commercial model fan high velocity I need motor DM514
did you check already the thermal fuse and capacitor??
Oct 02, 2015 | Duracraft Dryers
I own a Duracraft commercial grade high velocity fan, model DV-518. When I turned it on, the blades started to turn. Then there was a loud click and a small smell. I quickly turned the switch off. When...
Hi, I had the same pop noise and turned off immediately. So my question is, where is the capacitor, in the switch assembly or inside the motor?
Aug 30, 2013 | Duracraft Dryers
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
Fan vibrates real bad. Needs a new blade. 18 inch floor fan. Blade is weak and bends easily.
Stick a small weight to the end of one of the fan blades with some sellotape , run the fan , if the noise gets worse transfer the weight to another blade.
When the fan is running quietly go to the blade opposite to the one with the weight on and drill out a 10mm hole in the material.
Take the weight off and check for balance if it is still out drill another smaller hole in the blade till you get a balance
Drill the holes a the tip of the blade so that you get the best effect from the removal of material
This will save you buying a new blade
Oct 09, 2009 | Outdoor Concepts 18-Inch High Velocity...
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Where can i get a replacement 3 blade propellar? for a high velocity air circulator fan?
www.thefind.com/.../browse-high-velocity-industrial-fan use this site
Jul 19, 2009 | Bionaire Dryers
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
May 01, 2009 | Duracraft DFT-218W Table Fan
I need an owners manual for my Honeywell HF810 Mega Turbo high velocity Floor fan.
For a Honeywell HF-810 Mega Turbo High Velocity Floor Fan, pls click here.
You need Adobe Acrobat Reader to view/print these documents, to download click here.
Hope this be of initial help/idea. Pls post back how things turned up
or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 09, 2008 | Honeywell Heating & Cooling
Home Logo
48 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
