Question about Tivoli Henry Kloss Model Two FM/AM Radio
The tuning dial floats off of stations. Also it's sensitive to being touched without being turned, as in pressed inwards from the center or pushed up from the bottom down from the top. It can totally miss stations while being turned if it isn't pushed in from the center at the same time.
Preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
Apr 05, 2014 | 1997 Isuzu Hombre
Add stations to radio
try tuning to favorite station the push and hold down one of the favorite buttons for a few seconds, you should hear a beep or see the station number flash. if that doesn't work then there should be a button that has set on it. dial station, push set, push one of the favorite buttons and it should work.
Jan 26, 2013 | 2006 Hyundai Santa Fe
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Have lost four preset channels on my Technika DAB 109CR digital clock radio and lost manual so have nothing to consult to get back these stations. Everything live but showing only one station constantly
Finally sussed out how to (re)set presets, overall you need a little patience:
Probably best to press Autotune before we set off and let it do its thing.
Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play.
Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again)
Use dial to find station you want AND LEAVE to tune in.
Press AND hold presets down until number flashes.
Press jog/select once briefly (normally).
Press presets once briefly...it should now say "Saved"
Leave to save for a few seconds.
Voila!
You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
Feb 20, 2011 | Audio Players & Recorders
How do I change time and date on Toshiba DKT2020SD
Toshiba DKT2020 set work with a lot of different Toshiba systems. That being said this should get you in the right direction.
Date
  • From receptionist station, without lifting the handset, press "Intercom"
  • Dial "#651"
  • Dial the time in YY:MM:DD format.
  • Press "Redial" or "#".
  • Press speaker.
Time
  • Dial "#652"
  • Dial the time in military format HH:MM:SS.
  • Press speaker.
Day of the Week
  • Dial "#653"
  • Dial the day of the week (1-7).
  • Press speaker.
Nov 09, 2010 | Toshiba Lands Phones
I would like to change the pitch bend range in style edit mode- for example i would like to have it bend 12 notes rather than just 2. please help and thanks!
Hello :) I can help you :) First of all,press menu button.Then,on the screen touch MIXER TUNING.Then at the bottom of the screen press TUNING,and you'll find PB sensitivity.And then touch the number one the screen,which appears under PB sensitivity.At the end,just scroll tempo/value dial from 2 to 12 :) That's simple :)
Apr 22, 2009 | Korg Pa800 Synthesizer
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
Tuner
This sounds major.....
The signal detection used in both radios and TV sets is via special voltage sensitive diodes which alter capacity as the voltage across the diode changes.
You actually change the voltage across the diodes as you move the tuning dial.
In your case the diode only sees one voltage and is locked to a certain station, because you are not altering the capacity to re-tune to another station...
So it appears that you have lost the ability to alter the DC voltage across the diode...
The design of the tuning knob may be where this fault lies, where the physical action of turning the tuning knob does not transfer the mechanical action to the item that changes the DC voltage to the diode....maybe you have systen that uses a long cord would around pulleys that gives you nice control over the tuning maybe its just a broken tuning cord...
Maybe the tuning is done by just a simple variable resistor I'm not familiar with this system but I have given you the bascics to start on...Unplug the cord from the AC wall socket then remove the top of the cabinet and have a look to see what moves when you turn the tuning knob it will soon become apparent if there is nothing moving when you turn the knob and thus lead you on to the problem....
Maybe the knob is just loose on its drive shaft...
Cheers From YUBEUT
Nov 22, 2007 | Sharper Image SA253 CD Shelf System
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
dialing.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
Tivoli Henry Kloss Model Two FM/AM Radio Logo
41 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
