Open the door and hold the broil button down for 10 second. This should change it.
To Change ?C to ?F: Press OPTIONS, then 1 on the keypad for Fahrenheit. To convert back to Celsius , press OPTIONS, then 1 again on the keypad.Nov. 23, 2017
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
Here is the formula to compute farenheit to celsius and celsius to fahrenheit:
C is Celsius F is Farenheit C = 5/9 (F-32 F = 9/5 (C+32 Let's try converting 68 degrees Farenheit to celsius 5/9(68-32) Step 1: 68 less 32 is 36 Step 2: 5 divided by 9 is 0.5555555555555 Step 3: multiply the repeating decimal by 36 Step 4: your solution is 20 Now, convert 20 degrees Celsius to Farenheit to check your work. 9/5C +32 Step 1: 9 divided by 5 is 1.8 Step 2: 1.8 multiplied by 20 is 36 Step 3: 36 plus 32 = 68
You can switch the temperature mode between Fahrenheit to Celsius as follows: While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
TEMPERATURE - CELSIUS OR FARENHEIT If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows: Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
