Question about Xerox Phaser 3500/DN Laser Printer
Pcl6 error When I turn my printer on first thing in the morning and attempt to print a paper, error code appears. It says: Printer error Power Off/On, then says TSKEMU 2565. What can I do???
  • 2072 Answers
SOURCE: error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Posted on Feb 13, 2008
  • 70 Answers
SOURCE: Printer thinks its out of paper
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Posted on Oct 02, 2008
  • 65 Answers
SOURCE: Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Posted on Dec 07, 2008
  • 2072 Answers
SOURCE: Xerox 4150 prints from Macs but not from XP
Have you updated the machine firmware? At Xerox.com the machine firmware is there to download and install. Currently the firmeware is at level 10.100.45.018. Even if your machine is new you may have an older version of firmware.
That machine has had tons of firmware updates to it and uploading the machine to the newest level probably will resolve your problem.
There are some versions that fix 300 known problems at an update.
You have to follow the directions carefully, updating it can wipe out your LDAP settings if you use scan to E-mail etc.
If you have a maintenance agreement, or the machine is less than a year old, ( there is a one year on site warrantee on that machine for on site service) call 1-800-821-2797 and request a service call to update your firmware.
Those updates are really critical for that machine to operate properly.
Posted on Feb 12, 2009
  • 2072 Answers
SOURCE: error code PCL6 incomplete session by time out
That is normally caused by firmware corruption. You can go to Xerox.com, click on support and drivers, then in the search box enter pe120, then go to drivers and downloads and download the newest machine firmware . There are directions on how to install the firmware , make sure you follow them step by step. It's pretty easy and should resolve your problem.
Dell3100. Getting PCL error - press reset .tried to reinstall .nothing works
  1. Press Select ( > ) to clear the error on the printer.
  2. Reset the printer NVRAM:
    1. Press Menu.
    2. Press the down arrow until Configure appears, and then press Select ( > ).
    3. Press the down arrow until Maintenance appears, and then press Select ( > ).
    4. Press the down arrow until Init NVRAM appears, and then press Select ( > ).
    5. When Restart Printer appears, turn the printer off and then back on.
  3. Change the PCL driver to binary mode and attempt to print the document again.
    1. Right-click the printer's icon in Printers and Faxes, and then click Printing Preferences.
    2. Click the Advanced tab.
    3. Click Bitmap Smoothing and change the setting to On, and then click OK.
  4. If the error still occurs, Contact Technical Support.
Feb 12, 2015 | Dell Laser Printer 3100cn PCL6
My HP 6500A plus is giving an error code 0.6101 bed. Do you know what the problem is, is it practical to repair.
Do you mean the error 0x6101bed? This appears to be an error with the printer carriage or the sensors that detect paper in the trays. Unplug the USB cable if you are using that connection before trying the steps below.
Some people have solved the problem by turning off the printer and then removing the photo feed and output trays. Also remove any extras like a duplexer if you have one. Put in a sheet of plain paper. Then turn on the printer and quickly press the Menu button. Find the menu item for printer reports and select print status report (or a similar item). Push the paper gently into the printer pickup until the pickup spool catches the paper. Press Cancel and see if the printer ejects the sheet.
Some people have found that adding a few extra power on/off power cycles (5-6) helps. Then try to to move the print cartridges (gently - do not force anything) while the printer is off. While you are trying to move the print cartridges, check for any foreign objects in the printer. (A small piece of paper can cause the bed error.)
Make sure that the printer is on a firm surface wider than the printer. Pick it up and put it down again to shake things loose inside. At some point, the printer will go into a initialization step if you have solved the internal issue.
If these don't help, it may be that the internal frame and the rail that the printer cartridges ride on is bent. Then the solution is probably to replace the printer.
I hope this helps.
Oct 21, 2014 | HP Officejet 6500A Plus Wireless...
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
We have an HP 3600 printer we are trying to use with windows 7, and got the error, PCL XL Error, Subsystem : KERNEL, Error : MissingData, Operator: VendorUnique, Position : 81
First, delete the printer from the "devices and printers"
Second, go to www.hp.com/support
Download and install the latest drivers.
Now try printing.
Looks like the PCL driver got hosed.
Jun 07, 2011 | HP Office Equipment & Supplies
How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Jan 21, 2011 | Canon Office Equipment & Supplies
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
MP830 6A00 error & ON/OFF switch not working
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Jun 27, 2008 | Lexmark T644 Laser Printer
InDesign Printing problem; service error 49.4c02
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Jun 19, 2008 | HP LaserJet 4350dtn Printer
Xerox Phaser 3500/DN Laser Printer Logo
26 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
