Question about Ricoh Office Equipment & Supplies
Spotty print I have a Ricoh CL3500N printer. When I print images the right side on the paper has been printing spotty, nothing is wrong with the paper. I have tried different papers - they all come out the same
    Master:
  • 492 Answers
Could be a blockage on the printer head drive belt. Check to make sure the belt is not stripped or blocked.
Posted on Oct 18, 2013
  • 158 Answers
SOURCE: PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Posted on Aug 07, 2008
amfigue
SOURCE: Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Posted on Mar 24, 2009
RPFinney
  • 385 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Posted on Apr 21, 2009
sitehr
  • 94 Answers
SOURCE: D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Posted on Oct 16, 2009
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
Error code: color registration error and ultra-light, smudged printing on right side of paper
have you replaced all of the consumables?
drums X2 black and color
developer units X4 CMYK
transfer imaging belt X1
Fuser unit X1
if the unit has over 60k prints it will need to have these items replaced and once that is done the color registration will come back inline.
Jul 28, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh prints everything in left Margin
Check the printer properly and see what size paper the printer thinks is in there, or check at the controll panel.
-Carl, please let me know if this helps.
Jun 25, 2009 | Ricoh CL3500N Laser Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
LANGUAGE PROBLEM
The print properties are completely software based and have nothing to do with the printer itself. You've had to have installed the wrong version of the print driver or your operating system is set to the wrong default language. I'm assuming you would know if you were running a foreign copy of Windows so I would uninstall the printer and then download and reinstall the English version from the Ricoh website.
Jun 10, 2008 | Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Black streaks
HI there it would need a PCU (Photo Condustor Unit) or drum unit which ever you prefer.
Thanks J
Dec 12, 2007 | Ricoh Aficio CL3500N Laser Printer
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
