Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
Door will not open on unit - Sony MegaStorage CDP-CX455 400-Disc CD Changer
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
Tip
Door not opening in Equator / Hirundo (EZ3612CEE/EZ2512CEE/EZ1612V)
Door not opening in Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door in the unit is not opening it means that the unit has not completed the cycle selected or else there is something in the unit that has malfunctioned. In such cases if there are clothes in the unit, one tries to open the door by pulling the door handle which mostly results in breaking of the door handle and also the clothes in the unit cannot be removed
To avoid the breakage of the door handle and also the damage to the clothes you can follow the following procedure to open the door.
  1. Make sure that the machined is turned OFF.
  2. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  3. Turn the wash program knob to cycle no. 4 & advance the knob by 6 clicks in the clockwise direction.
  4. Turn the machine ON by pressing the ON/OFF Switch.
  5. You will observe that the machine starts draining out the water and also the drum starts moving ( goes into the spin cycle)
  6. Wait until the water is drained out of the machine, this can be understood by paying attention to the sound made by the drain pump when it initially starts draining out the water and once the water has been drained out.
  7. Once you are sure that all the water in the unit has drained out switch OFF the power.
  8. Try opening the door now, the door should open.
Once you have managed to open the door, it is advisable to reset the unit first before further using the machine. For the Reset Procedure Click Here
on Mar 01, 2010 | Washing Machines
I have a Whisper Driven 3/4 HP garage door opener and do not know if the wall unit to open the door has a problem. When you do to open the door, you have to keep your hand on the button until it opens all...
It could be that your electric eye has something blocking it and it senses that something is in the way. The eye is usually located about 18" above the floor on one side of the door and points over to a receptor on the other side of the door. Make sure that they are lined up properly, one may have been bumped.
Dec 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Help truck was stolen, I used remote control to "teach" truck how to open door... I reset door opener and relearned the remote..my question is do the remote have a new entry code when I learn, or remote is...
Ounce you reset ALL code of the garage door opener (engine hook up to the ceiling of the garage that open up the door), ounce you press the reset button on the unit, it disable all transmitter (portable or the one install in your vehicle). Your garage door opener has a receiver in it and your all units that you press on to open the door are the transmitter, so by pressing the reset button on the door opener, you erase all codes of all the transmitter that where programmed to open-up that door.
So if you teach your vehicle using a portable unit and you now reprogram your new vehicle with the SAME portable transmitter, then yes who ever has your stolen vehicle can come back with your stolen vehicle to your house and open up your garage door since you re-programmed the door opener using the SAME transmitter same code sent to the unite to active it).
Buy a new transmitter to re-programmed your new vehicle
Jul 13, 2014 | Building Materials
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
