Question about Video Game Consoles & Games
My system will not stay on - Video Game Consoles & Games
  • 118 Answers
Unplug and replug everything, try a different socket, try a different extension cord/power strip (or with none). I have gone through my fair share of power strips and extension cords ruined by power surges. Repost with more specific information if none of this works (like what happens before it goes off; can u turn it back on immediately afterward or not?) If you see a yellow light (ps3) or red ring (xbox 360) before it goes off your console needs fixing.
Posted on Oct 19, 2013
Saturn Vue 07 brake system warning light stays on and chimes intermittently--EB in off position
Check the warning sensor adjustment as the eb system may be worn enough to set it off if the adjustment is too close.
Feb 15, 2014 | Cars & Trucks
Vista-20p/ps series. when set for ARMED AWAY and after the delay period, the system become ARMED STAY. why is it?
If you arm and do not open the door programed as an entry/exit the system will still think you are inside. So it will only arm your perimeter and not the interior motions. Be prepared for your motions, if any, to set off your alarm if you arm, open door then close it and stay inside.
Sep 18, 2013 | Honeywell Ademco Vista 20p And 6160 Keypad...
Brake light and abs light is on
Red lite comes on at startup to ck. system. If amber lite stays on, ck. brake fluid level and see if emergency brake is partly up. This shows problem with anti lock system if it stays on, not main brake system. If all is ok with this but still stays on Have ABS system checked. Haynes repair manual, 95-2003 Windstar, all models.
Mar 24, 2013 | 2003 Ford Windstar
The 4x4 light stays on
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System
Oct 31, 2012 | BMW Cars & Trucks
Air bag light stays on
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
Oct 22, 2012 | Peugeot Cars & Trucks
What does the red light on the bord with letters SRS means? It stays on for few seconds after I start the car (Honda accord 1995). Thank you
srs means secondary restraint system. e.g air bags and things like that. when it stays on for a few seconds its because it is doing a systems check. if the light stays on all the time then there is a problem. hope i helped.
Jan 28, 2010 | 1995 Honda Accord
What is the SRS light? I have 1996 honda accord
the SRS stands for Supplemental Restraint System. Most people call it the air bags but the SRS system includes all of the sensors and control units for air bags, seat belt pre-tensioners and passenger detection systems on cars that are equiped with them
each time you start the car up the SRS control unit will do a self-test of the system to make sure all of the sensors are working properly. The SRS light will stay on while that test is conducted. If all is well and everything passes the on-board test the light will go out in about 7 seconds. If something is wrong the light will stay on.
whenever a failure is detected for any reason,the SRS light is turned on and the system is shut off. The air bags will not be deployed when the SRS light is on.
They call it a Supplemental Restraint System because your seat belts are your primary restraint system.
hope that answers your question
Nov 05, 2009 | 1996 Honda Accord
Motions don't stay active when doors and windows are on too.
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
F61 is showin up on my system ,an it wouldn stay on
It is the digital amp IC damaged.
Need replacement.
Nov 14, 2008 | Panasonic Home Theater System System
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
