Question about Dryers
My dryer will runs but doesnt get hot? Heating element?? I cant afford to have it repaired and would like to do it myself,
    Scholar:
  • 135 Answers
I have a temp fix. Make sure you use copper wire. Take the heating element out. Then look for the place that burned into.. Twist you copper wire tight around each side to make a complete connections. Make sure the copper wire is thick enough too. I had done this several times to buy me time to save up some money to buy a new element. Hope this helps
Posted on Oct 18, 2013
jsrock516
  • 5911 Answers
SOURCE: Kenmore Dryer Model 110
There are several things that can cause a dryer not to heat properly.  First and foremost, a dryer needs proper air flow in order to work properly.  Routine cleaning of the dryer vent hose should be done periodically.  I recommend once per season (4 times per year), depending on use.  If you haven't cleaned the dryer vent any time recently, start here first.  It could be that you have a simple clog somewhere.
Now...if you've already thought of that, you could actually have more going on INSIDE the dryer.  If your dryer is equipped with a removable front kick panel, remove it by inserting a putty knife along the top seam (about 2 inches in front each side) to release the retaining clips.  The panel should pull open, exposing the heating element and blower housing.  On some models the heat components can be accessed by removing the back of the dryer.
Stand back and watch the heating element with the dryer running.  If it is glowing and intermittently shutting off, this is NORMAL.  You probably have a clog some where INSIDE the dryer.  You will need to unplug the dryer and remove the air blower housing to see if it is clogged with lint.  I have found these blowers so clogged that the fan gets jammed with lint and snaps off at the shaft.  If the fan doesn't spin, there is no air flow and you clothes will not dry.  In this case, the blower fan will have to be replaced.
If the heating element is NOT glowing, and you have verified that the dryer is not clogged, you may have a failure with any of the following components:
HEATING ELEMENT - located inside a heat box.  Unplug dryer and remove connector leads from element.  Check resistance of the heating element.  It should be about 10 ohms.  If it is OPEN, the heating element is bad.
THERMAL CUT-OUT - located on the heater box housing.  Has two leads running to it.  Designed to protect the heating element in an overheat condition.  Check resistance to ensure it is reading something close to a SHORT (0 ohms).  If it is OPEN, it must be replaced.  It is highly recommended to replace the HI-LIMIT THERMOSTAT (which is also located on the heater box, closer to the heating element connectors).  The two components work in conjunction to regulate the heating element temperature.  If the TCO fails it is usually for a reason.  It could be a simple matter of general house cleaning, or it could be a failure of the hi limit thermostat.
I hope you find this information helpful.  Let me know what you find.  Post back with any comments and/or questions.
Posted on Oct 13, 2007
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
ginko
  • 19396 Answers
SOURCE: Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
Posted on May 18, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
dragonsthatk
  • 547 Answers
SOURCE: How do I replace a heating element for a Frigidaire Gallery Series Dryer (Mod GLEQ 332as2)?
please ask for Premium-Assistance:
Posted on Feb 13, 2009
Dryer gets warm but not hot
I will assume you have the thermostat set on high and checked the dryer vent to make sure it is not clogged with Lint, Mouse Nests, or GI Joes. (I have seen all of these.) There are two common broken bits that can cause this.
First, and most likely, is the heating element. Most electric dryers have two strings of heating elements that run next to each other. If one of them fails then the dryer will get warm, but not really hot. Depending on your dryer you either have to pull the back of the dryer off or pull the drum to inspect the heating element. When it's cool and unplugged it should be very obvious if it's broken. The heating elements look like springs, and one part will be brown and broken, probably near a ceramic insulator. If you are not sure, you can measure the resistance of each string with a multimeter. For a TEMPORARY repair, you can stretch the existing element's broken ends and put it back together. I stress that this is a temporary repair only because it will cause hot spot in the element and could be a fire risk. (Full Disclosure: My Mom has a dryer with this temporary repair that has worked since 1998. I'll get to it eventually.) If this is it, you can get a fully assembled heating element for $$, or you can save a lot by purchasing a restring kit instead. With the restring kit, you keep all of the metal bits and replace only the heating element wire and brackets. There are very good videos on youtube about how to install these properly. The key point is to pre-stretch the element before installing.
It is possible to bypass all the door closed and belt present to run the disassembled dryer for a few seconds to see if both elements get hot and turn red. This is patently unsafe, and you'll probably die from burns, electrocution, or entanglement with the electric motor. YMMV. Emphasis on "seconds" here, as the elements will burn out pretty quickly without airflow.
The other thing this could be is a thermostat. I don't know of any way to test these other than by replacement. They are fairly inexpensive compared to a fully assembled heating element.
Good Luck.
Feb 19, 2014 | LG Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
The dryer runs, but is not getting hot. Is there
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
My dryer runs but has no hot air and won't turn itself off.
you might need to replace the heating element
Sep 05, 2009 | Kenmore 63942 Dryer
I have a kenmore 80 series gas dryer. it's not staying hot. sometimes it will and sometimes it doesnt. i replaced the ignitor on it and its still not working what do you think?
This is probably the gas valve not working right. I would replace it. The ignitor is working and turning on the valve but it doesn't stay on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Dryers
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
Jul 15, 2009 | Kenmore Dryers
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the...
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
May 28, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
