FixYa.com
Tags:
GE Supermicro X5DAL-G E7505 Mainboard  Motherboard
X5DAL-G restart
posted by eng4081 on Sep 26, 2007
When I start the computer it goes to the windows 2000 display, the blue bar at the bottom of the screen reaches its end, the screen flickers, the computer clicks, then it starts over again. A technician said its the motherboard. They say it is no longer available. The other parts in the computer, including the power supply, are not compatible with the new motherboards. They are quoting me a new computer.
Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 26, 2007
Not Rated (0)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4488 votes
if theres a click, then its either the hard drive or the monitor click when it shuts off, motherboards don't make a sound.
When its starting up press F8 to enter safe mode and select last known good configuration and see if it starts as normal, but is sounds as though the boot.ini is damaged on a bad sector of the hard drive and either try a windows repair or replace the hard drive.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
no sound
i have problem with audio... Answer This...
Motherboards
microsoft says my os is not an...
Is there another way to get a... Answer This...
Motherboards
change the start up logo on a...
hi i would like to know how... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
