Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool DU1100XTPS9 dishwasher will not start. Lights on panel go on, but unit won't start. Recently, the screws on the inside of the door were all loose so possibly water got inside the front panel, but the dishwasher was working at that time. We tightened the panel back on and soon after we were unable start the unit.
  • Official Brand Answer
  • 401 Answers
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Posted on Oct 20, 2013
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
  • 93 Answers
SOURCE: bEEBING CONSTANTLY ADG7460 WHIRLPOOL NOT DRAINING
This dishwasher being only seven weeks old I suggest you contact the store where you bought this unit and tell them to book a service call and send a technition out to solve this,the reason I am suggesting this is that the unit is under guarentee and if you try to repair it will void any guarentee or warrentee that is on the machine.If you do work on it and something big and expensive goes wrong the store(manufacturer) will not honor there guarentee when they see that you worked on it so better to be safe than sorry.If you do not come right with them let me know and we can see what we can do from there.
Posted on Feb 05, 2009
SOURCE: dishwasher door won't latch closed
Please tell me, did you find out what's wrong - because this has happened to me now. :(
Posted on Feb 25, 2010
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
How do I remove the control panel safely?
Turn off power to the dishwasher at the circuit breaker panel.
Open the dishwasher door and start taking out the screws along the inside perimeter of the door. The door should then start coming apart for you.
If I remember this model correctly, it has a false front that can be removed (once you have removed the long screws holding it), by lifting up on the handle attached to the false front and pulling up and towards you.
Remember which screws go where, because I seem to recall that this unit has different sized screws.
Oct 19, 2014 | Bosch SHV45M03UC Built-in Dishwasher
Why won't my top drawer start
I am assuming you have a double drawer unit DD603. A drawer will not respond when you press Start button for several reasons. Assuming the panel lights are on, there could be a problem with the lid seal motor or the sensor that detects drawer is closed or blocked outlet hose or dirty panel. Take a damp clean cloth and wipe the inside of the drawer door panel. The dishwasher is very smart and checks for the condition of the dishwasher before starting. If turning off the mains power and turning it back on does not change the situation you will need a technician to attend to it.
Feb 07, 2013 | Fisher and Paykel Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
I have a Maytag Portable Dishwasher MDC4650A. When the start button is pressed, the unit will not run. Instead, the heated dry button illuminates with the start button when pressed and the other buttons...
I have the same dishwasher. I have found that this dishwasher had a control panel problem. After the dishwasher finishes washing you will noticed that the small green lights stay illuminated. Over time this causes the wire ribbon that connects the control panel to the circuit board to become burnt. I have already replaced my control panel once and now it has done it again. i am about to have to order another control panel. That is going to be another $140 dollars out of pocket. The part number for the control panel is( AP4365240). If you have the same dishwasher as I do it should be correct, Open the front door and look on the inside left and you will see the model of the dishwasher. Mine is MDC4650AWB1 Yours may be slightly different. look on the front of the control panel to see if it reads from left to right. High temp wash or extra rinse, sanitize, heated dry, start/cancel, delay, and cycle select. Since the dishwasher is designed poorly and the lights do not go off after drying, if you can after the dishwasher finishes with it's washing and drying be sure to open the door for about 2 min and the lights will go out by themselves. Then you can close it back. This will allow your dishwashr to last longer without the wires burning out. To verify that it is the control panel after you carefully remove it take a look at the wire ribbon that runs from the control panel to the circuit board. Here is a quick class on how to remove the control panel. open the door and on both sides you will find 4 star tip screws. remove them and seperate the door from the backing. After that you will need a socket to remove some hex tip screws that holds the control panel to the door. be sure to remove the black box that contains the circuit board. take the cover off and carefully disconnect the wires. the wire ribbon that connects the control panel is a little tricky. You have to seperate the plastic connector block and the ribbon will slide right out. after you remove it go to http://www.appliancepartspros.com/Appliance-Parts/whirlpool-panel--con-item-number-ap4365240.aspx and you will be able to order the part online to replace it. Be careful not to drop any of the screws and also pay attention to the door latch when you move it to the side while you work so that you do not break it.
Sep 14, 2011 | Maytag 24" Tall Tub Portable Dishwasher -...
Control panel unresponsive
open up the inner door shell after powering down the unit from the power source,wiggle and remove and replace all ribbon cable connections on the electronic control panels and any other connections you can see,moisture corrodes these connections after years and removing and re-installing these will sometimes wipe off any corrosion for a better connection to the machine the screws are on the inside of the door to access the control panel
Jun 19, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Kitchen circut was accidently turned off. Now whirlpool gold disher will not work(unit was not running and the door was not closed all the way when circuit was turned off, All circuit breakers are on)...
You can put the unit into diagnostics (press the following keys in order within 6 seconds HEATED DRY, NORMAL, HEATED DRY, NORMAL all the lights will come on and it will start a diag cycle) and see if it recovers. If not, you are looking at a electronic control, and yes you CAN change the part yourself.
Mar 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
There is power to the unit, but there is no power to the touch pad
This could be the door switch. Its located behind the control panel. Shut off the breaker to your dishwasher and remove the screws on the inside of the door behind the panel. Locate the door switch and check.
Replace if needed. On some units there are two switches to check side by side.
Dec 28, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
How to access thermo fuse on Whirlpool dishwasher DU920QWDB4
Had all screws removed on inside of door, but had to remove front outside panel to access screw with held panel to door.
Dec 27, 2009 | Whirlpool 24 in. DU920QWD Built-in...
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
101 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
