Question about Sony CDP-CX450 400-Disc CD Changer
How to reset the device - Sony CDP-CX450 400-Disc CD Changer
Factory reset trio g5
You are talking about a generic Android software reset?
Google gives instructions here: https://support.google.com/android/answer/6088915?hl=en
Factory reset your Android device
  1. Open your device's Settings app .
  2. Under "Personal," tap Backup & reset. If needed, enter your PIN, pattern, or password.
  3. Tap Factory data reset Reset phone or Reset tablet. If needed, enter your PIN, pattern, or password.
  4. To erase all data from your device's internal storage, tap Erase everything.
  5. When your device has finished erasing, pick the option to restart.
  6. Set up your device and restore your backed-up data.
If you can't open your device's Settings app, you can try factory resetting your Android device using its power and volume buttons. We recommend seeing your manufacturer's support site for device-specific instructions.
Aug 23, 2017 | Tablets & eReaders
Reset code
Hello
FYI - a hard reset deletes ALL data on the cell phone so make sure you backup your contacts before performing these steps.
Enter *2767*3855#.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Menu > Settings > Reset
Reset various settings to the factory default values. Select which settings to reset. You must enter your device password
to reset the settings.
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your
device is still responsive but a program is frozen, close the program using the task manager. If your device is frozen and
unresponsive, remove the battery, replace the battery, and turn on the device.
Nov 03, 2013 | Samsung star II duos GT-C6712
How to to know my master reset code?
master reset codes differ from mobile device to device. There is no particular way to determine the exact reset code for a device by going through the device. Master reset codes are usually floated around mobile device experts. Depending on the device i could supply you with the reset code.
Hope this solution has been helpful?
Feb 03, 2011 | Cell Phones
What software can reprogram my sony ericsson k580i??
Soft Reset
To soft reset the device, remove and re-insert the battery.
Master Reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Master Reset.
  4. Scroll to and select desired reset:
    • Reset Settings: this option clears the settings only
    • Reset Device: this option resets the entire device
  5. Press Continue.
  6. The device will be restarted, press Continue.
Feb 13, 2010 | Sony Ericsson K800i Cellular Phone
Just used garmin nuvi it worked fine went into the store and now the unit is locked/frozen on the garmin logo screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Make sure to charge it fully.
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Oct 09, 2009 | Tomtom ONE 130 GPS Receiver
Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Do a RESET:
  1. Lift the antenna
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 260W screen is blinking and beeping. Wont do anything else
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sure give it a try.
  1. Lift the antenna
Aug 02, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
  2. Locate the small circle with a dot inside (very small)
  1. Lift the antenna
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
  1. Lift the antenna
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Sony CDP-CX450 400-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
