Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
INET light is on not able to connect to internet
  • 3 Answers
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Posted on Oct 18, 2013
I have a Westinghouse smart TV and I have the WiFi home but it is not connecting to the internet or netflix what must I do
Hi Samantha
Assuming that the WiFi is working around the house with other devices like iPhone / iPad and other computers?
The Westinghouse TV is just another device connecting to your Home Network via a WiFi Signal. Unless it uses a dedicated Ethernet Cable at the back of the set > to Modem Router Box.
So... the problem would require setting up the Westinghouse smart TV with the necessary settings.
Netflix is just a web site and will become available when the TV connects to your Network & External Internet GateWay.
First, you need to know your WiFi Name & Password.
I find it easier to use the iPhone as a test device to check the WiFi signal and set up details first. To Test Password etc.
There is a helpful tool on the App Store called iNet - Network Scanner - See Below
So... you must find the settings for Network on your smart tv.
Setting the tv for DHCP is allowing it to Automatically search for an internet connection. Thats what most people do.
Just choose your WiFi name (SSID) & Password.
But... you can choose your own IP addresses if you like to keep all your devices on a known address.
Eg. Your Router or Modem Box Gateway address 192.168.1.1
Each of the other devices have a unique address.
Computer 1 192.168.1.10
Computer 2 192.168.1.20
Camera 1 192.168.1.100
SmartPhone 192.168.1.130
You can use the end numbers between 1 & 255
Your Gateway might also use another IP Group e.g. 10.0.0.0
Your really only interested in making the last numbers different from each other.
Cheers
iNet - Network Scanner APP
The iNet Network Scanner and Toolbox for Mac
How to Connect Your SmartPhone to WiFi at Home or the Office
How to Install Wireless Router for Beginners How to Install Wireless...
Oct 14, 2016 | Computers & Internet
Globe access point
APN: Go to MENU, SERVICES, DATA ACCOUNTS, GPRS, create NEW SETTINGS.1. if your globe sim card is not yet activated for inet, then configure it manually.. go to connectivity then go to access points, make a new one and name it Globe inet..then on the APN put this "http.globe.com.ph" without the "
2. then after that, go to internet profiles, make a new profile and name it globe inet.. name it Globe inet. then choose to use a proxy.. then enter this proxy address "203.177.91.131".. and then it the proxy server port, put "80".. then on the access point choose Globe inet..
3. now you need to make another internet profile.. so make a new one. name it "proxy".. then choose to use proxy, and then enter this proxy "195.189.142.132" then on the proxy server port put "80"..then on the access point put Globe inet..
4. ok now your done configuring your globe inet settings,. next step is to go to games and apps, then choose settings, then choose profiles, and add profile.. name the profile "proxy". then on the internet profile choose "proxy" then save it and activate it..
Feb 14, 2012 | LG Cell Phones
How to confirm that the BSNL modem is having problem & cannot be used any more if INET light is continuously blinking?
There are several lights on your modem/router. Each one has a function and signals whether it is working correctly by the color it is displaying and a few other factors.
All of the lights on your modem/router should be green and solid - EXCEPT for 2 which are for your internet and wireless services. Blinking means activity. If you INET light is continuously blinking that means its healthy. Blinking means activity. The internet always has activity. The blinking does not signal your activity - it signals the traffic and connection on the internet. Your wireless connection also has a light which should show activity and availability. A blinking light on your wireless connection means that either someone is connected wireless and using the internet or that the connection is up and available for wireless access.
All of your lights should be green. If you see a red or yellow light - regardless of whether it is flashing or not - it means that there is trouble or problems that need to be corrected.
Each light is marked with its function. They should say things like "power", "link", Internet or INET, and "wireless". When you turn on the modem/router during your first set up, let it power up and finish its testing before connecting your pc and turning it on. The modem will test each light, make them all go from red/yellow to green - then make them all turn solid green (not in that exact order) and this is all normal. You will know when it is done when all lights are solid green and stop blinking and/or moving (except the INET & wireless lights which will be constantly blinking). When all lights other then those two are green and steady - then its time to connect the cable to your pc and power it up.
If you are having problems with your internet connection - you can rule out the cause being your modem/router by following the instructions above. When you rule out that the modem/router is not the cause, you can continue by checking your PC.
For a wired connection (wired meaning that you are connecting your computer to the internet by using a cord/cable) the first thing you want to do is make sure that the computer is automatically sensing the connection.
Your computer should automatically sense that there is a live internet connection when you connect the ethernet cord from the modem/router to the pc. When its working right, the computer will display a connection picture which is called an "icon" on the bottom right side of your screen near the clock area. Sometimes there is a downward arrow by the clock which needs to be clicked on to expland this area and show all icons for running programs. If you see a downward pointing arrow by your clock on the bottom right side of your screen, click on the arrow.
Test that it is sensing the internet connection by unplugging the ethernet cable from your pc and watch the bottom right side of the screen at the same time. Unplug it and repeat if necessary while watching the bottom corner to see a change which indicates it senses the connection. A normal internet connection icon looks like the picture of a computer monitor. Some glow green when they are active and the ethernet cable is connected. Some show a red "X" over the picture of the monitor on the bottom right side of your screen when the internet connection is down or not working. Some will say "cable disconnected" when you unplug the ethernet cord. Some show "Cable now connected" when you plug it back in. You should see something change and/or appear if your pc is picking up the internet connection correctly. When you have verified this as true - then you can continue on to the next step of troubleshooting the internet connection.
DSL service is an internet connection that is always on. Its considered a "live" connection. DSL connections usually do not require any set up (programming or changing settings). The only time that this is not the case is when someone tries to to set up a dial up connection like aol over the top of a dsl connection. You can check this by going to your control panel, click on internet options, and choose the "connection" tab at the top. In the connection area box there should be "nothing". The connection area box is for dial up connection settings. If a dial up service was set up in the pc it would show it here (you would see AOL dial up ect). If you see a dial up connection set up and you know that you have dsl, click on the remove box and delete it from this area.
You do not need to install anything from a disk to establish an internet connection if you have a dsl line. That means you dont need an "aol" disk or software to make the internet work.
to start the internet click on the blue "e" on your desktop which stands for internet explorer.
If you have any questions you can reply to my solution by going into the problem you posted on Fixya and click on the "reply" option.
Mar 03, 2011 | Samson Technology X6v ADSL ModemWireless...
How to connect to internet to Linux 5 server enterprise edition in my dual boot desktop
type in these commands I assume you are using a Debian flavor
sudo nano /etc/network/interfaces auto eth0 iface eth0 inet dhcp (this is for DHCP, skip to CTRL commands below if DHCP) iface eth0 inet static (this is for a static IP) address x.x.x.x netmask x.x.x.x gateway x.x.x.x
CTRL-O CTRL-X
sudo nano /etc/resolv.conf nameserver x.x.x.x (DNS here) nameserver x.x.x.x CTRL-O CTRL-X
sudo /etc/init.d/networking restart
Dec 18, 2009 | Computers & Internet
Having a connection problem with ZyXEL 660Hw-D1
Did you duy a service. If not buy one. If has have to have broadband.
Aug 30, 2009 | Zyxel Prestige 660HW Wireless Router
Internet connection
This is due to ur inet connection, please contact ur ISP...!!!
Thankyou
Jun 16, 2008 | HP Pavilion dv9000z Notebook
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
57 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
