Question about Frigidaire Compact Air Conditioner
6000 air btu conditioner faa067p7a
How do I remove front panel. Need to clean mold of the directional louvers. Removed 3 screws but still cannot get panel off.
2 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Posted on Jun 10, 2008
How does plastic head cover pull off on a head split system Panasonic split system air conditioner
Look for 2/3 small plastic covers for screws just under the louver(s) one at each end of the air discharge opening and one in the centre (maybe). Pry these off gently with a small screwdriver and you will see the screws underneath. Remove the louver first to make access easier. There may also be a screw in the centre just above the louver.
Once all the screws are out, the cover should lift up easily from the bottom and then release from the top clips. If it doesn't come off easily, you may have missed a screw.
Jan 26, 2016 | Panasonic Heating & Cooling
How many btu is this air conditioner model #FAA067P7A
Good Afternoon Friend, this is Z. That's a great question!
I show that your Frigidaire air conditioner FAA067P7A has a cooling capacity of 6,000 BTU's. I hope this information helps to some degree. If you need further assistance, please feel free to reconnect.
May 25, 2014 | Frigidaire Compact Air Conditioner
Horizontal louvers
Get yourself up to the machine on a safe platform. Remove any covers that will come off easy, or tie them up out of the way. Remov e the filters. Often the whole front can be removed by just taking out a couple of screws.
Once exposed, look for something out of place. Put the louver back where it belongs to see how the hinge works. It may have jumped out of it's proper position. Ease it back in position and check it for freedom of movement. If it looks good, put it all back together.
Nov 26, 2013 | Carrier Heating & Cooling
Mold in sharp cv-p10mc water reservoir
Dominic,
My only solution is to take the unit in for warranty service. The cooled air has a musty smell to it, too. Does yours? And did you get this issue resolved?
Sep 08, 2012 | Sharp CV-P10NC Portable Air Conditioner,...
How do i remove the front part
there is usually screws hidden be hide the filter
Jun 20, 2012 | Danby 15,000 BTU Premier Window Air...
Air conditioner dripping water
Try pouring some bleach in drain.
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
Mold inside unit
There is a product on the market that will prevent mold from growing in your air conditioner.You should be able to find it at a refrigeration supply house.Just take the product and place it in the area where the water collects.There is also a product to help you clean your unit of contaminants on the heat exchanger surfaces.It simply sprays on,and can be later rinsed off.Its usually a straight forward matter to remove the cover from an air conditioner.Usually no more than 4 screws.Some units will slide out of their covers,after removing the screws that keep them locked in place,and some covers simply lift off from the rest of the unit once the screws are removed.In either case the rest of the unit minus the cover will remain intact,and can be cleaned.Cleaning the unit will almost always make it work better too,so your killing two birds with one stone.
Jun 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MS12- Mold Problem
I have had to clean mine on a yearly basis. On mine once I have the cover off, I can remove a couple more screws, disconnect the baffle motor and the drain connection and pull the drain pan off to gain access to the barrel fan. The first time I cleaned it with a small bottle brush and bleach water. I scrubbed each fin individually, alot of work! I used a pressure bottle(for the garden with wand) to rinse the fan. Then the next year I used a Shark Steamer to clean and kill the mold, still alot of work but easier then scrubbing. I am going to try rinsing it more often with white vinegar to kill the mold.
Jul 26, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Frigidaire Compact Air Conditioner Logo
27 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
