Question about Trion SE800E Smoke Eater / Smoke Eliminator
Trion SE800e clicking, snapping/sparking incessantly
1 thinks its wet , 1 sparks and snaps.
I took the blades and a washrag in the shower with me and cleaned them. Then I put them in front of the air vent for 8-10 hours. Then I put them back in the unit. Sparking and snapping could be from dirt moving through the unit.
Nov 21, 2013 | Sharper Image Hybrid GP Germicidal Air...
Green light is on red light is off
Replace the Air Flow Sensor (AFS). The thermistor could be compromised.
Sep 13, 2011 | Trion SE1400 Air Purifier
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a Trion Max 5 1400. when the air is flowing past, I turn on the power switch and both lights come on, then go right off. We have had the unit for awhile, and have had the power module repaired...
Read the owner's manual for troubleshooting, it has a lot of information.
https://www.trioniaq.com/getfile2.aspx?fileid=9024
http://www.trionparts.com/trion-max-5-1400-air-cleaner-parts.html
Check the ionization wires are there, one may be broken and touching the ground plates.
Also check to see if the wires have a growth touching the ground plates. If so, clean the grids and wires; let it dry. Water and electricity don't play nice.
Jan 20, 2010 | Air Purifiers
Sparks shooting down sides of ozone plates
Disconnect the power and give it a good cleaning with a SOFT BRISTLE PAINT BRUSH. Outside is best. Blow it out gently with canned air after you brush the dirt loose.
Jul 25, 2009 | Ecoquest Flair Air Purifier
Clicking is likely sparking/arcing rather than something mechanic
Sparking is what it does; Google the words ionizer purifier sparking and you will be let to explanations on how they use sparking to clean. Honeywell has been using that Technology for decades. Don't worry sparking in the unit is OK
Jul 12, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Ozone function causing blue spark and snapping
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 13, 2009 | Air Purifiers
Trion SE800E Smoke Eater / Smoke Eliminator Logo
50 people viewed this question
Top Trion Air Purifiers Experts
Are you a Trion Air Purifier Expert? Answer questions, earn points and help others
