Question about Maytag MHWZ400T Front Load Washer
Maytag 4000 series manual
The washer makes a beeping sound when I push the start button, but it won't lite up to choose options or stay on. It does have power connected.
jamesdaly
SOURCE: epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
Posted on Jun 06, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
  • 1531 Answers
SOURCE: Maytag 3000 series locked close and inoperable
if there is still water in the machine then you need to drain the water.
this can be done by using a wet dry shop vac and attach it to the end of the drain hose and remove the water that way. this will normally unlock the door
also check the wiring to the drain pump this does effect the door. you may aslo try pushing the clear or cancel button for three to five seconds.
i hope this was helpful to your problem.
Posted on Feb 06, 2010
Testimonial: "I will have to get my hands on a wet/dry shop vac, but the super quick response is greatly appreciated. Hope it works."
livewire874
  • 618 Answers
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Posted on Nov 20, 2010
jsrock516
  • 5911 Answers
SOURCE: Im getting a F20 code
"F20" is a "No Water Detect" error code. This usually means you have very little water entering the machine, or no water at all. The following link explains the error code in more detail and steps necessary to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: Each one of thes washers comes with a technical data sheet inside. The tech sheet lists all error codes, troubleshooting information, wiring diagrams, diagnostics procedures and illustrations. To access, you need to remove the lower toe panel directly below the door. The screws are located under the bottom front edge. With the screws removed, the panel will drop down and can be removed. If the tech sheet is not located directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
I mention the tech sheet, because you may need to refer to it in order to accurately troubleshoot.
If you have any questions, please post back and let me know. I hope this information is helpful to you
Posted on Aug 11, 2011
MAYTAG 5000 SERIES WITH STEAM WASHER WONT START
the lid isnt being detected as closed
the switches have a fault in them
Dec 05, 2014 | Maytag Washing Machines
Maytag 4000 series washer mhwe450wr01 just beeps once when I press the power button
Maytag's address used to be #1 Dependability Blvd, Newton Iowa. Not any more. Now they're made elsewhere by a company that bought the name and not the quality.
Oct 14, 2014 | Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Aug 28, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag washer
It helps trying to actually weigh your dirty linen. Try to wash within what is mentioned in your manual. Also see that the door is closed firmly. Would be useful if you'd post back results.....
Maytag MHWZ400T Front Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
