Question about Poulan Garden
Pouland pro 200 blower want start seems to not fire
  • 906 Answers
You need to check the magneto
Posted on Jan 25, 2015
4 Suggested Answers
  • 6 Answers
SOURCE: poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
  • 15 Answers
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
What is the Air Gap on a Poulan Pro PVB 200 Blower?
I am not sure of the exact gap but I have been told you can use a business card thickness to set the gap. You might try that. Hope this helps. In addition, go to youtube.com videos will show you how to do it.
Sep 16, 2015 | Poulan Garden
What direction does the drive belt go on a pouland pro riding mower
if you are sitting in the seat and look straight down,it goes clockwise"on the front from drivers side to passengers side" see pics,2nd is wrong pic
Apr 01, 2015 | Poulan Pro 42" Deck Lawn Tractor
New blower will not fire
Check for spark at the plug by using a simple spark checker tool. Got to have both or it won't start.
Feb 26, 2014 | Poulan Pro Gas Blower Vac BVM200VS
Poulan pro leaf blower model bvm200vs
Pull off the muffler and you should see the piston and ring. Look for carbon buildup...poke the ring to see if it is stuck in it's groove...there should be a bit of spring in the ring. You might see carbon scoring. Stuck ring means low compression which means no start. Carbon buildup is due to too much oil in fuel mixture.
Jul 09, 2013 | Garden
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
My saw say on the side pouland 305 pro so how many cc is it
a pouland pro is a (low h.p. saw) and at 46cc i wouldn't run bigger than an 18 inch bar , its asking to much from the clutch and motor
May 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan bvm pro 200 gas blower not getting gas
Sep 22, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
49 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
