Question about Dynex DX-L32-10A 32" LCD HDTV
TV won't display anything. Screen goes white.
    Scholar:
    New Friend:
  • 118 Answers
I would recommend pursuing repair options with a licensed service technician, as most likely this is caused by a hardware malfunction. Bear in mind, repairs may not be cost effective, and therefore, may be cheaper to pursue replacement TV options.
Posted on Oct 30, 2013
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Olympus X-42 Camera - the screen has gone white (with a few thin green/purple vertical lines). When I switch on the camera the screen is white, there is no picture or menu displayed. I have checked by...
There doesn't appear to be a solution. I have had to send mine off to be repaired. They don't provide a camera case but it is a very necessary piece of aquipment. I was told that the screen had been pressed. I can only think that this occured when travelling on the bus when someone has sat next to me. Olympus should supply a camera case.
Jan 17, 2010 | Cameras
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Camera goes straight to F2000 and displays a white screen
Can you adjust aperture in manual mode?
If no, then aperture drive is jammed/broken in the lens.
If yes but it doesn't change anything, then CCD can't process light correctly and needs replacement.
Apr 02, 2009 | Fuji FinePix S5000 Digital Camera
White Screen of Death. TV locks up
You will need to replace the power supply or get fix because there aren't too many service parts available anymore.
Jun 07, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dynex DX-L32-10A 32" LCD HDTV Logo
32 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
