Question about GE Dishwashers
MY GE MONOGRAM DISHWASHER ZBD6880K00SS IS STUCK IN EITHER LOCK OR HEATED DRY MODE. I AM A DISABLED LOCKSMITH AND THINK I CAN FIX WITH SOME ADVICE. HOW DO I EITHER UNFREEZE OR DETERMINE IF NEW TOUCH PANEL WILL FIX PROBLEM? I SHUT BREAKER SEVERAL TIMES , NO HELP? RANDY
4 Suggested Answers
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: My Whirlpool quiet wash plus 940 series is stuck on "lock out"
Same problem and I was about to call for service. Opened the dishwasher to get the model number and noticed a sticker stating to hold down the Heated Dry button for 5 seconds to clear the lock light. Worked for me!
Posted on Aug 23, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Jul 27, 2017 | GE GDWT160R Dishwasher
I need to unlock my ge profile pdw9200jcc dishwasher
To unlock the dishwasher controls, press and hold the HEATED DRY pad for 3 seconds.
The light above the lock pad will turn off. To lock the dishwasher, press and hold the
HEATED DRY pad for 3 seconds. The light above the LOCK pad will turn on.
If you need a replacement manual you can get one on the link below.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55015.PDF
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | GE Kitchen Ranges
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
The heated dry button will no longer work on my GE Mono. dishwash
most often they are one unit or "circuit board" and you will need to replace every thing, if you can turn off power and take off front door panel you should be able to "see" switch componet or look in your owners manual ...hee hee
May 21, 2009 | GE Monogram® ZBD6880NSS Stainless Steel...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Monogram dishwasher
I think I had and now have again the same issue. I called a repair man who replace the entire control panel. He state the moisture caused it to blow out. The moisture???? it's a dishwasher. Well a year later the problem has returned. I can only use one setting at this point.
Dec 28, 2007 | GE Dishwashers
Dishwashers Logo
145 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
