Panasonic lc so83r1pg - Computers & Internet
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
What the differential betwen LC and UB type battery, for example LC-X1220P and UB12220. thanks.
Specs Volt 12 Amps 22 Length 7.13 Width 3 Height 6.57 Terminals NB Weight (17.5) Manufacturer Universal Power Model # UB12220 Universal 12 Volt 22AH Battery UB12220 Universal 12 Volt 22AH Battery
Specs Volt 12 Amps 20 Length 7.126 Width 2.992 Height 6.575 Terminals NB Weight (14.56) Manufacturer Panasonic Model # LC-X1220P Panasonic 12 Volt 20AH BatteryLC-X1220P Panasonic 12 Volt 20AH Battery
Dec 28, 2010 | Panasonic LC-X1220AP - UPS battery - 1 x...
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- djstvrepair@comcast.net
Sep 10, 2009 | Televison & Video
Rechargeable battery
Hi, try looking on ebay, user name; itl-e. His shop name is; Component-shop. A wide range of batteries supplied including a 6V 5AH which sells for about £8 including p&p. Your Panasonic battery is rated at 6V 4.2AH, so the replacement will last slightly longer between charges. If you want an exact (Panasonic) replacement, try putting "Panasonic LC-R064R2CH into google.
Hpoe this helps! Bob.
Oct 05, 2008 | VAX Appliances V037 Stick Wet/Dry Vacuum
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
