Question about Tools & Hardware - Others
I have a Ryobi BD4600 bench sander, while using it the belt sander stopped, but the disc keeps running. I have tried restarting and giving the belt a push,nothing happens. Please advise John
SOURCE: Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Posted on Jul 11, 2009
mikeymiddles
  • 58 Answers
SOURCE: Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
  • 384 Answers
SOURCE: I have a Ryobi 4x36 Belt Sander (BD4600). I've
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
jyackle5
  • 8197 Answers
SOURCE: ryobi bd4600 4" belt/6" disc
You can get the manual on the link below.
http://dl.owneriq.net/2/29376206-744b-4024-a838-8e43f307520b.pdf
Posted on May 23, 2011
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
Jan 13, 2015 | Sander Tools & Hardware - Others
Need a manual for a mastercraft 55-3554-4 sander
If you find best disc snaders in 2018, easy to assemble, easy to use go to the link Best Disc Sanders For Sanding In 2018
Dec 20, 2013 | Ryobi Mastercraft Belt/disc Sander Belt...
The disc sander on my ryobi belt/disc sander DB4800 is loose and wobbling
Wen is the best disc/belt combo sander. Wen always best for his price. Cheak the link Best Disc Sanders Selection Guide Before You Buy
Aug 19, 2013 | Ryobi Garden
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
Jan 08, 2009 | Tools & Hardware - Others
Loose sanding belt
CHANGING DRIVE BELT
  Remove the cover.
the motor pulley.
Good Luck!  Middles
Tools & Hardware - Others Logo
130 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
