Question about Lexmark T640 Laser Printer
Service transfer roll
What is the service transfer roll and where is it in the printer. I need to know what to order for the classroom printer
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
Hi, The transfer roller is the roller located untherneath the tonercartridge. Partnumber 40X0130
Posted on Jan 06, 2014
2 Suggested Answers
  • 85 Answers
SOURCE: What is the service transfer roll? What does it
Most often caused by high voltage power supply caused by toner spill. It is located bellow the transfer roller under the paper guide.
Posted on Oct 18, 2013
How I fix the error 917 service transfer roll
Try replacing/reseating transfer roll.
  1. The right and left transfer arm assemblies
  2. The high voltage power supply (HVPS)
  3. The main engine/system board
Feb 18, 2015 | Lexmark E350d Laser Printer
What is the service transfer roll? What does it look like? How do I replace it for the classroom printer?
Oct 18, 2013 | Lexmark T640 Laser Printer
Need to replace transfer belt cleaner and 2nd bias transfer roll
Both are probably still good but the HFSI (High Frequency Service Item) counter needs to be reset. Unless something has changed with them that has to be done with the service laptop hooked to machine with a serial cable and using M24 diagnostics.
Jun 20, 2012 | Xerox WorkCentre M-24 Color Copier
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
Mar 30, 2012 | IBM Infoprint 1552n Printer
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
91700 Service Transfer Roll was appearing on my screen so I ordered a new one replaced it and it is still showing me the error.
Here's an article in the Lexmark website to guide you on what to do when having 917.00 Service Transfer Roll error. Just click on this link: http://bit.ly/d7uyzZ. Follow the instructions carefully. Basically, when having this kind of error, you will need to primarily change the transfer roll or the High Voltage Power Supply. If this doesn't help, it may require service to replace the system board assembly, transfer roll left and right arm.
Jun 01, 2010 | Lexmark T640 Laser Printer
Error 917 - Service Transfer Roller. I have replaced the transfer roller on my lexmark e350d, but I am still getting the error. Not sure where to go at this point.
Hello my friend.First maake sure the printer is powered off before making any checks on the transfer roll or associated parts for personal safety and to prevent damage to the printer.
1.Check the transfer roll for any signs
of toner buildup, surface damage to the roll, oil or other contaminants on the surface of the roll. Replace the transfer roll as necessary.
2.Check the left transfer roll arm
assembly to make sure it is fastened and locked in the down position. If the arm is not locked down, check to ensure the arm is not broken and will lock into the EP frame correctly.
Check the left transfer arm assembly spring for proper operation.
3.Check the right transfer arm assembly to make sure it is fastened
and locked in the down position. If the arm is not locked down, check to make sure the arm is not broken and will lock into the EP frame correctly.
Check the right transfer arm assembly spring for proper operation. For any background problems, check to ensure the
contact to the HVPS board is correct and that there is approximately 0ohms resistance between the transfer roll shaft and the HVPS contact.
4 . The voltage changes from +24 V dc with the printer idle to 0 V dc when the printer runs the print test. If the voltage is incorrect, check the continuity of line J10-3 in the front
cable harness to the HVPS. If there is no continuity, replace the cable harness. If there is continuity, replace the HVPS. If the problem continues, replace the engine board.
Feb 08, 2010 | Office Equipment & Supplies
Error code 917.00 "service transfer roller" won't clear
This is a transfer roll error. Take the toner cartridge out and clean the area under it. The transfer roll is a roller which is right under the toner cartridge. make sure the ie is clean . It may need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 30, 2009 | Lexmark T640 Laser Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
How to pull up HP printer that was somehow deleted?
Hi, Do you know if you have a computer that is the print server? Because the drivers for the printer have to be somewhere.
Is it only your classroom that can no longer see the printer?
Whichever the server is the printer may need to be re-installed on there first before you can capture it in the classroom.
Nov 21, 2007 | HP Color LaserJet 2600n Printer
Lexmark T640 Laser Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
