Question about IBM Wheelwriter 30 Typewriter
IBM Weelwriter 5
When you turn it on this happens.the wheel spins and stops carrage moves left to right and stops the 3 leds blink 1 11/2 2 and the keys dont work I might of hit the wrong buttons i was tryin to set lf and rt margins
  • Anonymous Jun 15, 2008
    same prpblem, took the keyboard connectors of and then reconnected them, still same problem, thanks
  • 328 Answers
You probably need a new keyboard. Check and make sure the 2 keyboard connectors are secure in the main board. Open the top cover and look down by the keyboard and you will see the connectors. Keyboard costs about $ 75.00 to repair. Plus labor for a repairman to replace it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 27, 2007
SOURCE:
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Carrage jam
1) Open door so print heads move to the center
2) Unplug the unit. (Don't turn off, just unplug!)
3) Open back door
4) Look inside the back left side for a small black gear (About the size of a quarter)
5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
6) Keep spinning the gear until the plate moves all the way forward.
7) Grab the plate and try moving it forward more.
8) Put the back on and close the top.
9) Turn the unit back on.
10) Open the top again
11) Unplug the unit again. (Don't turn off, just unplug!)
12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
13) Make sure that the print heads slide left to right smoothly
14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
Ref - http://www.fixyourownprinter.com/forums/inkjet/22798
May 07, 2011 | HP Officejet 7210 All-In-One InkJet...
Model 6784 -wheel won't spin
The wheel is probably moving but the print solenoid cap is probably broken. We sell them with installation instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Jun 02, 2010 | IBM Wheelwriter 6 Typewriter
It only spins in one place then stops
As said, if it beeps 9 times after stopping, than this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
Have fun
Avi
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
IBM Netvista MB 49p1599 Front Panel Pinout
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
Mar 07, 2009 | IBM (49P1599) Motherboard
IBM Wheelwriter 6 Problem
The lights blinking indicates an error code, that mean a keyboard error or posibly a problem in the start up procedure. This is a problem that would have to be solved in a repair shop.
Oct 27, 2008 | IBM Wheelwriter 30 Typewriter
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
IBM Wheelwriter 30 Typewriter Logo
78 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
