Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Very little water stream from the water dispenser.
    Habit-Forming:
    New Friend:
  • 53 Answers
Make sure your water feed line is not to long, they come with 1/4" conneting but if to long you lose wter pressure, need to increase tubing to 3/8" tubing also make sure water valve is wide open an water line is not kinked anywhere
Posted on Oct 19, 2013
Can't get my water dispenser on refrigerator to confirm calibration
Slow stream can be filter needs replacement. What is confirm calibration?
Feb 14, 2016 | Whirlpool Refrigerators
I have a side by side with water/ice dispenser. The water is dispensing but the stream is nearly non-existent.
Check the filter also look at hose that is coiled in back of fridg to see if it is kinked. lastly check filter on water feed You will have to turn water off for this There is a screen inside connector . One other possibilty is the water line tap is plugged if the tap is the kind that uses a saddle to pierce the line Back it out just a little and re-tighten
Jan 30, 2016 | LG Refrigerators
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
My icemaker is mking a little bit ice, why
It sounds like not enough water to fill the ice maker.
Do you also have a water dispenser? If so does it take a long time to fill a glass?
Do you have a water filter installed? If so it may need changing. On my Kenmore the filter can be removed without turning the whole house water supply off and I would imagine that's true on all refrigerators, but I'm not positive. If there is a shut off valve near the water entry point to the refrigerator you can use that valve to be safe. Also you might want to shut that valve off and disconnect the water tube from the refrigerator and then open the shut off valve into a large pot to eyeball the pressure of the water. If the stream is somewhat stronger than what comes out from the water dispenser there is an obstruction either in the filter or internal to the refrigerator.. If not any of these, ask for further suggestions.
Aug 16, 2014 | Refrigerators
We have a primo water dispenser, model # 900183 and the water is dispensing as one slow stream not a fast full stram of water as it use to. how do we fix that?
Had the same problem. I tried cleaning it as instruction on the copany website with bleach and water. I also unplugged it for a couple of days to see if the lines were frozen. Finally out of frustration I put my mouth on the water dispenser, pushed the button, and sucked some water out and spat it out. After that I did the same thing again but blew into it instead. I did this a couple of times and my water dispenser went from a trickle to flowing like the day I first got it. Also, you should probably clean the water dispenser after doing this, just saying.
Apr 27, 2013 | Refrigerators
The powder dispenser on my ls 610a dishwasher does not seem to work properly. There is always powder left in the dispenser and the dishes are not always washed properly.
Try to make sure that the path for water isn't blocked to the dispenser. Ours will do that too if we forget to leave some space for the streaming water to hit the little tray.
Dec 23, 2009 | Ariston Technologies LL64WNA Built-in...
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
JCD2389GES water dispenser over-runs and also starts on own
Low water pressure can be very problematic when it comes to icemaker/water dispenser water inlet valves. If there is low water pressure to the valve, the valve may not seat correctly causing icemaker fill tubes to freeze, icemakers to over/under fill or water dispensers to leak or not shut off fast enough. Check the water pressure to the valve like this:
Turn off the water supply to the refrigerator and remove the water supply line from the water inlet valve behind the refrigerator.
Put the end of the water line in a bucket and turn the water supply on. There should be a good stream of water jetting from the tube. If there is not, the water supply shut off valve is probably plugged and needs to be replaced or there could be an in-line water filter that needs to be replaced. Only use a drill style (non-self piercing) saddle valve http://www.repairclinic.com/SSPartDetail.aspx?s=t-584723-%3d%3di584723&PartID=584723 for the water supply.
If there is a good stream, the water inlet valve that the water line connects to at the back of the refrigerator should be replaced.
*Note: Reverse Osmosis (R/O) systems should never be used to supply water to icemakers.
TheRepairGuru --- www.repairclinic.com
Jan 27, 2009 | Jenn-Air JCD2389G Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
