Question about Ovens
Sunbeam Pizza oven recipy book - Ovens
Oven cleaned but will not open,has been cleaning for three hours
This is a safety feature of the oven. When the oven cools down you should be able to unlatch and open the oven. I accidentally did this (closed the latch) when cooking a pizza, fortunately I turned to oven off and the pizza did not burn.
I hope this helps.
Feb 09, 2016 | Ovens
I have a licoln 1000 pizza oven it will cook outside of pizza not bottom why
check the fingers especially the bottoms ones , they could be clogged with dirt or pizza particles. just clean them
May 27, 2014 | Lincoln Conveyor Oven - 1132-080-A
Zanolli pizza oven, fan working and flame is not working
Sorry, I am not familiar with that oven.
Oct 19, 2011 | Ovens
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
Pizza dough spilled into top of oven.
Pizza sauce tends to be highly conductive and corrosive. If it got into the keypad or control board it is probably causing a short. It may be able to be carefully cleaned with alcohol but some disassembly is required.
Jun 26, 2010 | Fisher and Paykel AeroTech - OS302M...
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Dipending upon what kind pizza you want to use.
Subway using the same toster to Bake personal pizza (90 Second for 1 and 120 sec for 2 pizza
Oct 17, 2009 | TurboChef TORNADO Electric Oven
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
