Onkyo How To Connect
I have an Onkyo M-5140 Amplifier and P-3160 Preamplifier and i think i am missing a cord to connect the two together. do you connect the power outlet from the receiver to the ac outlet on the amplifier? or do I need another cord to connect from the unswitched to the ac outlet or the ac outlet on the reciever to the ac outlet on the amplifier and if so what cord do i need? sorry if that sounds confusing and thank you for any help you can provide
  • 71 Answers
SOURCE: help connecting up amplifier and surround sound.
Ok here`s what you have to do first turn off all three applinces you will need 3 (rca) jacks then on your tv should have a yellow colour input jack its like a hole place one end of the jack into the video or yellow hole and the other jack into the video or yellow hole to the back of your dvd .then behind your dvd they are other inputs for audio take the the colours should be red and white one jack will be (L) left the other side will be right (R) place the other two jacks into it .Then behind the amplifer Look for the two red and white inputs place the jackes from dvd into it make sure on the amplifer you place the jacks in the aux input or line in input .then switch on all the applinces and on the amp using the remote or on the front panel press the aux or line in button then play somthing to hear if it works
Any problems Please send me a request
And please to rate me Thank you
Posted on Jan 13, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
  • 8546 Answers
SOURCE: need to connect yamaha htr6130 receiver to an elan amplifier
Why don't we deal with the issues separately?
What are you trying to accomplish with speakers all around the house. Or did you mean around the ROOM?
You can't slave other amps off of this unit and have volume or source control at the receiver. It lacks any Preamp Outputs.
Tell us what you want to do, how things are connected (in detail) right now and maybe we can help you out.
It might also be helpful to know WHY you need to have multiple amps.
Posted on Feb 22, 2010
  • 8546 Answers
SOURCE: Can i connect a seperate
Nope, you would need specific pre-outs for external amps for the front channels. That is what the sub pre-out is and a powered sub IS an external amp.
How much bigger an amp were you considering? 100 watts is pretty good and to make an appreciable (audible difference) you might have to double it.
Read this paragraph:
Posted on Dec 31, 2010
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
I have Onkyo TX-NR709 is it possible for me to use my BOSE 809 series 3 as my front speakers, I have PA Behringer EPX2800 can I connect all these?
Hello, You can use all three of these together. You could use the front (red and white) preout on the back of the 709 which will connect into the red and white input on the amplifier. Then you will connect the Bose speakers to the amplifier. Thanks, FJD
Mar 05, 2016 | Onkyo Audio Players & Recorders
How to hookup a onkyo TX-SV424 amplifier to a RCS HD50LPW175
? 7:00
Apr 22, 2012 - Uploaded by Tampatec
Dec 10, 2015 | RCA HD50LPW175 50" HDTV
Cant get channel a & b to stay on together
You need to connect all the remote cables together then turn on the multiple room button on the onkyo p-301 preamp if u have it the it should turn on.
Dec 17, 2012 | Onkyo M-501 Amplifier
Looking for stock remote
The stock remote for the Onkyo P-301 is a RC-200s because I have the same preamp.
Jul 30, 2012 | Onkyo P-301 Stereo Preamplifier R1 Preamp...
I want to connect a turntable to my Onkyo TXSR601 but it dosnt have a phono connection. Where should I connect into for best results?
Your Onkyo has no suitable input for turntable. I suggest you to use this or this preapmlifie, connect the turntable at the preamplifier input andthe preamplifier output at any available input at the Onkyo (cd, tapein or video in, at the red and white connectors). Of course you can buy any phono preamplifier from any shop and connect it with the same procedure. The models before is just a sugestion.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 04, 2011 | Onkyo TX-SR601 Receiver
Trying to connect bose speakers to my insignia flat screen tv?
this can be done with a receiver hook-up. The speaker are connected to the receiver and the television is also connected to the receive input circuits. This should be explained in the owners manual of the television and the receiver. Another way to connect the speakers is to have a preamplifier and a amplifier. Where the speakers are connected to the amplifier and the television is connected to the preamplifier. The preamplifier output is connected to the amplifier input. This all also should be explained in the owners manuals of the products.It is important to read these manuals to find the correct connection methods and correct cables to use for the connections. If you still cannot do the connections , Then call customer service for the devises to get help with the procedures. Hope this helps you with your problem.
Mar 28, 2009 | Insignia LCDTV26 26 in. Television
Fine audio equipment from Japanese manufacturer's like Onkyo is typically "stand-alone", meaning there often is no universal remote control available that will work a given unit; those that will work are rarely capable of accessing all the features & functions such units bet is an original equipment remote control; recommend you try going to this site:
and search for links to the P-3160 preamp & how to contact the Sales Department about cost & availability...
Jan 12, 2009 | Onkyo LS-V955 System
How do you connect a Marantz 240 Power Amp to a Marantz 3600 preamplifier? Do you have a diagram?
first preamplifier out-to amplifier line in-or-aux in.,and then amplifier out to your loudspeakers.
Jul 16, 2008 | Marantz Audio Players & Recorders
How to connect an equalizer
the monitor its basicaly the switch who connect or separate the preamplifier from the amplifier and that the part that you can connect the equalizer the only way it using an external preamplifier. sorry for the bad news
Jun 10, 2007 | Yamaha HTR-5850 Receiver
53 people viewed this question
