Computers & Internet Logo
S
Said Halal Posted on Oct 18, 2013
I am looking for Tenor configuration manager - Quintum Computers & Internet
How much cost a selmer paris series III model 64 jubilee edition tenor saxophone
I have 51 years experience as a sax player. A new listed price for this saxophone is $7319.00 on sale. Optional finishes would include silver plate-Add $940.00. Gold plate- Add $12,490.00. Better deals can be had from private sales and from various music stores. In my opinion there are better saxophones although I have owned a Paris Selmer tenor sax since 1967.
1helpful
2helpful
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Hello sir i lost my tenor ax series gateway license file by doing reformat flash now i need license file how i can get?
http://www.quintum.com/
go to the link above and then go to the support tab then look for chat or telephone number and get a rep they can give you a new or temp license tell them it got lost and they will replace.
I have a tenor dx 6120 connects to an omnipcx office but i cannot make a voip call with it although I 've configured it to make sip call
Unfortunately, there are any number of reasons this could be a problem. The only sure way to tell what's going on is to look at the SIP traffic directly.
If you are up for it, here are the steps you'll have to take:
1. Download and install Wireshark(it's free) from www.wireshark.org
2. Install wireshark on a PC and connect it to the same switch as the Tenor,
3. Configure the switch to use the PC port as a monitor port for the port the tenor is connected to; you need a managed switch for this.
4. Start a capture with Wireshark for the appropriate interface. You'll probably see a shocking amount of traffic on your network all of a sudden. Don't worry, we're going to filter out the stuff that doesn't matter and it will be much more manageable.
5. Click the Telephony tab and select "VOIP calls". Try to make a call or two and see if this provides any useful info.
6. If #5 didn't help, go back to Telephony and select the "SIP" filter. This will provide more basic info on what is going on with the Tenor by showing every SIP packet. If you don't know anything about SIP it can be pretty hard to read though - you may need to post results here and let us take a look.
1helpful
I need quintum CLI configuration manual
pls cq
http://www.quintum.com/support/mgmt/index.shtml
u find GUI configuration software & also CLI Configuration manual
1helpful
2answers
Guitar strings on a mandolin.
Looking at your desired notes the mandolin is standard tuned to gdae.
So three of the four notes are already available, just put the "d" mando strings where the "g" ones would go and the "g" ones where the "D" ones would go the highest is already a "e" and I am sure the "a" would tune up to a "B" with little risk.
You can also
look at string sets made for the madochello or possbly octave mandolin.
Good luck,
The dude.
Who can help solve my problem
The CM stands for "Configuration Manager", in other words, that is the GUI. The Tenor firmware either starts with a P or an S (e.g. P104-11-00 or S105-01-01)
Top Quintum Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
