I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be opened only from the intercom switch and all my 2 remotes are not working. the battery voltage ok. what should i do?
    Problem Solver:
  • 19 Answers
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Posted on Nov 21, 2013
4 Suggested Answers
  • 28 Answers
SOURCE: Steps to program additional remotes for Centurion gate motor
hi
are the remotes sorted
Posted on Feb 23, 2010
  • 28 Answers
SOURCE: Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
jdvillanueva
  • 2098 Answers
SOURCE: My Centurion remote has stopped
Hi wargoman,
I've suspected that your remote control have a bad solder joints most especially in the infrared emitter section. I would advice you to resolder on that little board, sometimes it is hard to spot you may use table lamp to find it. Be careful not to short the lead.
Gudluck!
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 01, 2011
How to program a ET BLU MIX remote on a older type centurion d5 gate motor
Ask the shop what to do when their suggestion does not work.
Oct 02, 2014 | Televison & Video
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Is it posible to program my Centurion D3 remotes to open an E.T MK111 garage door motor
No. It's not possible. There is no setup codes to synchronize with.
Nov 27, 2013 | Televison & Video
YOU MUSt test the r.control see the photo atttached, when you hit any key the LED must be ON, and otherwise, you must open the keypads for clean from oxide, corrosion, etc. and clean the springs contacts battery, replace by new ones full charge type alkalynes. and test again.Of ocurse you can have problem too with the control motor.
God bless you
Nov 25, 2013 | Televison & Video
Can i please get help on how to programme my sentry remotes to operate my d3 centurion gate motor.
Programming procedure is too much to type in by this window. If you wish to get more details, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 26, 2013 | Sony Remote Control RMT-D301 p/n:148907111
How to programme a digikey 4 button remote on a centurion d3 gate motor
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 08, 2012 | Cars & Trucks
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
I have bought an additional remote which I must programme with my centurion sliding gate motor. I need some assistance, but I don't want the other remotes to go out of sync. Please assist. Thanx Dawie
Steps to Programming Centurion Nova Remotes
1. Unlock the motor cover with your Centurion Key, remove this cover.
2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase.
3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins.
4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate.
5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button.
6. If further Remotes/Transmitters are to be added to the system, repeat step 5.
7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins.
8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Aug 28, 2010 | Televison & Video
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
Electro Med Services...
