Question about Cell Phones
Emer per djem - Cell Phones
98 Dodg3 Durango emer brake is released,red light is on &when put in gear it's as driving with emer brakes on recently serp belt changed trans belts adjustd..transfercase have anything to do with it
The red brake light also means there is a problem with regular brakes , not just for emergency or parking brake . This light if on an emergency brake is released you have front disc brake problems or you have a brake fluid leak an the master cylinder is empty ! The transfer case has nothing to do with the brakes ! Have a qualified repair shop check it !
Dec 02, 2016 | Cars & Trucks
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
2000 impala,emer. flasher and turn signal not working; have replaced turn signal switch
you may have a bad flasher relay. its also known as a hazard relay, or turn signal flasher.
Jul 18, 2012 | Chevrolet Impala Cars & Trucks
My fog storm 1700 turns on but the machine will not heat up
Replace the circuit breaker by opening up the machine. You do this by unscrewing all the screws and exposing the circuit board. You will then be able to detach the 2 cables going to the circuit breaker and unscrew the circuit breaker's thread on the outside thus releasing the circuit breaker. Hope it helps!
DJ EM-A
jmavila02.wix.com/djem-a
Nov 18, 2011 | American DJ Fogstorm 1700hd Fog Machine W/...
Anyone can help me why i experiencing emer calls
is ur mobile is china if yes then it due to ime no pls go to the service center
Jan 21, 2010 | Ericsson Cell Phones
MY PHONE IS ON EMER ONLY MODE HOW DO i
just removed the back of the cell phone and it reset itself
Aug 29, 2009 | Samsung SGH-A137 Cell Phone
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
