Question about Garden
John Deere LT 133 shift problem. It used to move into any gear very smoothly and easily but now you have to push very hard to get it anywhere. Reverse is almost impossible and will even grind gears if you don't hold pressure in reverse like there is no detent.
  • Chris B Oct 21, 2013
    Shift lever is hard to move (binding)
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 850 Answers
SOURCE: gator lt wheel doesn't turn when in grass/ slips easily and need
only one wheel is driven in slow !
fast engages the other motor [2 wheels drive]
the wheels being plastic or poly wont grip & on the early gators as there is no speed controler in the system to prevent wheel spin!
only other way would be to add rubbr cleets to the wheels! or try changing to wheel barrow or scooter style pump up wheels
if you need more help just email me as i can help with modifaction process like more powerfull motor setup etc etc.
CHEERS Rob
Posted on Jul 20, 2009
ghost45
  • 1280 Answers
SOURCE: 2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
Posted on Oct 18, 2009
ftw1952
  • 10319 Answers
SOURCE: 2003 Chevy Trailblazer LT gear shift won't move out of park
The park shift lock needs adjustment. The solenoid that locks irt inplace maybe the cause of this
Posted on Apr 04, 2010
133 lt wiring diagram foa john deere
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 31, 2017 | John Deere Garden
What does the fuse look like on a john deere lawn tracter LT 133 serial number 2801914451?
Most likely like this.....
and it will be near the starter solenoid
Sep 29, 2014 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
I have a 1999 John Deere LT-133 when I put it in any gear or try to engage the blade the engine won't stay running. Do you have any solutions for this?
sounds like the safety switch under the seat may be bad. unhook and / or bypass the switch. if this fixes the problem then replace the switch. hope this helps you
Aug 16, 2011 | John Deere Garden
I have a John Deere LT 133 lawn mower, when I release the clutch/brake pedal the motor will will not continue to run.
There will be a faulty safety switch somewhere. Most likely the one on the seat. Regards Phil
Apr 10, 2011 | John Deere Garden
John Deere
did you try the manufacturers web site?
another place to try is www.archive.org
Nov 03, 2009 | Garden
Need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Sep 06, 2009 | Garden
May 24, 2009 | Garden
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
