Question about Midea Oil Filled Indoor Heater - USA, INC
Oil filled heater won't heat up. It does turn on and the light illuminates but no heat. I't been in basement for the summer.
  • 90 Answers
Could be that the thermostat is disconnecting because it senses too warm.
Plug the heater to the wall, turn on the switches.
Turn the thermostat knob all the way to min. It should make a click sound and the heater should not get warm.
Turn the thermostat knob all the way to max. It should make a click sound and the heater should get warm.
If the heater is still not warming up and/or you don't hear clicks, then the heater has bigger a problem.
With the cheap prices of the heaters, it is not worth trying to have an electrician check it out. Just buy a new one.
Posted on Oct 18, 2013
It worked fine in AC mode but when we tried to turn on the heat it wont heat
wow what a question. Is it gas, electric, heat pump, oil fired? Is it in your basement, trailer closet, or on the roof? How old is it? If you did seasonal maintenance like changing the filter in the blower compartment you may have left the blower door loose. If it has been made in the last 20 years the draft inducer may not want to begin spinning after sitting all summer. If its older maybe the pilot light is out and a thermocouple needs to be replaced. Its the best I can do without more information. Hope this helps, good luck.
Oct 13, 2014 | Heating & Cooling
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
Heater does not heat when turned on. indicator light stays red
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Jan 30, 2010 | Honeywell HZ-710 Oil Filled Radiator...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
240 or 120
240V used 1/2 the power of 120v It shoudl be wired on a dedicated circuit.
Jan 26, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Won't heat
Try calling delonghi america at 1800 322 3848
Dec 14, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Midea Oil Filled Indoor Heater - USA, INC Logo
79 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
