Question about Ricoh KR-30SP 35mm SLR Camera
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked at the advice people have given other people with this problem and tried holding the shutter down while trying to advance and holding the rewind button down and trying to advance and nothing has worked. Please help me I have a project due really soon and need to take pictures!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Posted on Nov 06, 2013
SOURCE: Shutter Release button
Did you try changing the aperture? Depending on the lighting in the area, you may want to change this accordingly, if you put it in AUTO, and you're in a dark room the shutter might not open immediately.
Posted on Sep 14, 2008
SOURCE: Ricoh KR-5 SUPER II Shutter will not activate.
I doubt you still need help with this considering it's over 8 months later... but the same thing has been happening to me lately, I've had to force the self timer to start by giving it a little push, once it gets going it starts to work normally again.
Posted on Oct 01, 2008
  • 185 Answers
SOURCE: The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Posted on Dec 07, 2008
  • 185 Answers
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
facebook496
SOURCE: sears ks-2/ricoh xr-7 film advance and shutter release problem
There is a good chance you can repair this yourself. If you advance the film winder handle so that you can see the bottom of it there should be a screw visible. remove this screw to take off the plastic cover of the winder handle. The actual winder is metal and attached to the camera with a screw that can become loose. I believe the metal lever is keyed to only go on the winder shaft at the correct place. Reattach the metal winder arm and then place the plastic cover back on. One thing to watch is that the plastic cover has a small tab at the shaft end, so it needs to go on with a clamshell motion rather than straight down. My camera has the small tab broken off so I have a bit of hot glue holding on that end, which also acts to keep the shaft screw from moving.
Posted on Mar 14, 2013
The Film advance lever is stuck, how can I fix this?
This camera is 42 years old. Sounds like a mechanical problem, but I doubt you are going to find any company or individual who knows how to fix it, or can find parts for it, if needed.
Suggest you keep this museum piece as a conversation starter, and invest in a newer model.
If you want to stay with Canon, the Elan 7N and Rebel T2 film cameras are 'only' about 13 years old. I see Elans on eBay starting at $70 (body only).
Jul 04, 2017 | Photography
The rewind button on my diana camera is stuck OUT - as well as that I can't rewind my film as the rewind lever is stuck - can you please help?
Take your camera to photo developer who has the dark room. They will open your camera in dark room and remove the film without any damage to it. Once film is out you can see whats actually the problem, it can be gear tooth misaligned or something.
May 08, 2011 | Lomo Diana Mini 586 Film Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
My nikon fm10 film advance lever is stuck, i can't do anything with it
You may end up sacrificing the used film or you can rewind it early.
I have had it happen that the film sprocket holes had striped out causing the advance sprocket to get out of sync with the film making it ride up onto the area between sprockets and creating a jam.
If you can, rewind the film onto the feed roll to preserve the exposed portion and then remove it from the camera.
Try the film advance then with an empty camera, releasing the shutter and repeating the cycle to determine if the advance mechanism will now act as it should; if it does, then the film was probably at fault and it may never happen again.
If you cannot respool the film, I would take it to a professional photo lab and have them unload the camera in a dark room if you want to try to save the pictures already on it.
Oct 01, 2009 | Nikon FM10 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Scratched negatives; broken tractor drive on two cameras
There doesn't seem to be a pattern with any of the Fuji films (I use Sensia and Velvia, exclusively, and have never had a problem in my Canon EOS). There are reports that the Fuji Pro films will gum up the sprockets in a camera, thanks to an adhesive strip at the end of the roll, but I'm not sure if the regular 400 speed film has the same problem. You might try a thorough cleaning, and see if it is still happening. I'm not surprised that 400 speed comes out a tad dark. Try dropping to 200 speed (I generally won't use anything above 100 speed, unless it is black&while).
Cheers
Nov 10, 2008 | Photography
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Honywell Pentax Spotmatic
Dear Spotomatic
Most film processing stores will take the film into a darkroom and get it out that way, also most camera supply stores sell light tight bags that you could take the film out of the camera without exposing the fim to light. Make sure you do not open the camera back even in a dark room.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 14, 2008 | Pentax K1000 35mm SLR Camera
Ricoh KR-30SP 35mm SLR Camera Logo
213 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
