Question about Reebok Exercise & Fitness
My reebok TR 8.0 is stopping and then starting again. The LED loses power and lights up again and start to work. This seems to me that it might be within the console. I don't know if there is a sensor that can temporarily cut power. The motor is a little weak. I can stop it with a stick on the flywheel. Any thoughts?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
See the video attached. lube the rollers bearing front+back
However test the terminal voltage motor, if there ARE voltage the motor is faulty. see my personal TIPS.
2) test the output from control board for terminal input voltage motor, If there ARE NOT voltage the board is faulty.
3) test the drivel belt motor, for loose or break, and adjust or replace the belt. tight for 1/4" deflection
God bless you
Posted on Oct 19, 2013
Why does my reebok 8400c treadmill stop after a minute or two? The control panel works, but the tread will stop. I can start it manually, but it stops again after 1 or 2 minutes.
You have to check the speed sensor potion. Try to align the speed sensor or check is there is any dust accumulate on speed sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 27, 2016 | Reebok Exercise & Fitness
What can cause 2000Nissan Frontier run good for 8-10miles then loss power, sputter then quit running?
Sounds like it could have a stopped up catalytic converter, on way to tell for sure is when it loses power check the exhaust coming out if there is little air flow it is stopped up and simply can't breathe,
Aug 15, 2014 | Cars & Trucks
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
MY CANON IT NOT WORKING IT'S FLASHING 8 TIMES
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon PIXMA iP90 Mobile Printer
Reebok rx3000 treadmill. panel lights up fine. 2 of the 10 speed buttons will not imput and the start button will not start the treadmill. checked the power panel. led lights to voltage light up fine, but...
it is two items in this case. The light on the PWM will light if you force the belt to move. I would start with a lower board replacement. If it works fine then you need a new console. I have seen this when people use the heart touch bars on the treadmill and get a static shock. this can ruin the console.
Apr 18, 2009 | Reebok 8050 ES Treadmill
Reebok 365 TR
Never mind -- took it back and got another one. I hope I don't have to do this every time i change the batteries.
Jan 16, 2009 | Reebok New York Giants Eli Manning Jersey
Setting the time
It took us 2 days, but my husband and I finally figured this out.
Press and HOLD the Mode button until the time display starts to flash. Press the mode button again until the hours are flashing.
Use the Stop/Start and Reset buttons to move the time up or down.
Press the mode button again until everything stops flashing.
Oct 16, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
Setting time
To get the manual from the Reebok site, you need to know the model number (not 10M). The Reebok site says you can look on your user manual for this ?!?. If I had my user manual, why would I be online looking to download a user manual?
Anyway, there is another response below that answered my question.....
You have to hold down the mode button until the time starts flashing, hit the mode button again to get hours. Adjust with the stop/start button.
Hope that helps...
Aug 30, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
Exercise & Fitness Logo
69 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
